Old 12-11-2011, 10:50 PM   #1
wilberweb
wilberweb's Avatar
What column to use?
Hi, Guys
I am working on my 55 Chevy 1/2 ton big cab.
My question is
I want a tilt wheel overdrive shift indicator on the column with cruise built in the blinker.
also with a dimmer switch on the blinker as well with no key in the column. I want to use the key in the dash. I found that the vans use this kind of set up but they don't have the cruise or the dimmer switch in the column. So if I want a cruise in the column built into the blinker, I may need to go with an Ididit column.It seems all of the columns that are set up this way are with the key in the column.Are there any vans that came with all of these options I mentioned. Or will I need to go to Ididit for this application?
-Larry
wilberweb is offline   Reply With Quote
Old 12-12-2011, 01:27 AM   #2
jmsaunders
jmsaunders's Avatar
Re: What column to use?
Have you thought about using an add on cruise control like the following
http://www.dakotadigital.com/index.c...prod/prd46.htm
jmsaunders is offline   Reply With Quote
Old 12-12-2011, 02:24 AM   #3
wilberweb
wilberweb's Avatar
jmsaunders,
Thanks for the link.
I thought about it just briefly. I was going to go with an add on cruise, if I can't find all the options I was looking for.
-Larry
