Old 12-12-2011, 12:08 AM   #1
rayfinseats
Defrost
I rewired my 83 k10 w/ac and want to know what makes the defrost turn on since I eliminated my selector switch. I removed the AC and made my own metal dash. I have a cable to turn the heat on and off but I want to know what sends the head up the defrost vents. Is there a flapper door or something I can use inside the dash? I just want to be able to switch from heat to defrost, nothing else. I get heat down below when I turn on the blower. I still have the defrost ducting but not the center dash ducts. I ditched part 21 and all the parts in the right column pictured.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=58
rayfinseats is offline   Reply With Quote
Old 12-12-2011, 12:37 AM   #2
rayfinseats
Re: Defrost
Is it the lever right by the heat flapper door lever? Post #3 picture 3.
http://67-72chevytrucks.com/vboard/s...d.php?t=460942
Old 12-12-2011, 10:24 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Defrost
just above the gas pedal
inside air box there is ajustments too
you can make the flow all up and down or, mostly up or, mostly down
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
