Old 12-12-2011, 06:00 AM   #1
Stepper86
Stepper86's Avatar
would these heads fit on a 305?
Hi guyīs.
Would GM 14101128 heads(from a corvette) fit on a 305? I found a set dirt cheap, and started toying with the idea to replace the smog tops on the 305 in my truck. Have heard that they should give decent low end tourqe on 350īs.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 12-12-2011, 09:49 AM   #2
sethv
sethv's Avatar
Re: would these heads fit on a 305?
Should fit, 350's and 305's share the same block iirc. I know of people who run 305 heads on 350s.
Good luck.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 12-12-2011, 09:56 AM   #3
Stepper86
Stepper86's Avatar
Thanks sethv.
Im a bit conserned about valve clearence, intake on these heads are 2,02" Im afraid that they might catch on the cylinder wall. I know that 1,94" will clear, just not sure about going bigger.
The fleet:
Old 12-12-2011, 10:26 AM   #4
bnb0221
you wont have any problems, they will clear the cyl
bnb0221 is offline   Reply With Quote
Old 12-12-2011, 10:36 AM   #5
Pop's C-10
Pop's C-10's Avatar
you will look some compresion ratio going from a 58cc head to a 64 cc head & on a 305, it needs to keep every advantage it has..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 12-12-2011, 10:41 AM   #6
Stepper86
Stepper86's Avatar
Im pretty sure that L98 heads are 58cc, but I might be wrong.
The fleet:
Old 12-12-2011, 11:07 AM   #7
notyo_cheez
Not sure I'd do this unless the 305 gets an overhaul first. Any time you break a seal on the long block assembly it's best to go through everything. That's been my experience. Think of it as a yin/yang philosophy, any time you add something new you take away something else.
I'm getting a Goodwrench 350 4-bolt crate and scrapping the 305, it hasn't been run in at least 10 years and not sure how well after sitting that long. To me it's not worth rebuilding or keeping esp. when a new crate is actually cheaper than rebuilding an older engine.
notyo_cheez is offline   Reply With Quote
Old 12-12-2011, 12:12 PM   #8
Stepper86
Stepper86's Avatar
The deal was to good to pass up, the heads are brand new still in their GM boxes. got them for 300$ (at least in my part of the woods thatīs a good deal) So if I donīt use them in the truck they can sit on the shelf until I find something to put them in.
I might swap for an LS later if I can find a good one here, or trade the truck for a 68 Firebird cab that I have my eyes on:-)
The fleet:
Old 12-12-2011, 12:17 PM   #9
rayfinseats
Go for it. If not sure call a machine shop. I don't agree with "Any time you break a seal on the long block assembly it's best to go through everything.
rayfinseats is offline   Reply With Quote
Old 12-12-2011, 02:14 PM   #10
gGMC DOG
Here's a link to some heads that have been flowed as well as from some other sources.
http://www.thirdgen.org/techboard/tb...-headflow.html
gGMC DOG is offline   Reply With Quote
Old 12-12-2011, 03:19 PM   #11
notyo_cheez
It's up to you, of course. Just sharing my experience with engines. Any time I've done a new top end the rings failed.
Old 12-13-2011, 03:19 PM   #12
406 Q-ship
406 Q-ship's Avatar
Originally Posted by Stepper86 View Post
Thanks sethv.
2.02's will NOT clear the 305 bore.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 12-13-2011, 04:13 PM   #13
Cue-Ball
Cue-Ball's Avatar
Even if the valves clear the cylinder wall without touching, you're going to encounter severe shrouding issues. Combined with the drop in compression you're going to kill your power, not increase it. I say definitely do not put those heads on a 305. You're going to do much more harm than good.
Cue-Ball is offline   Reply With Quote
