Old 12-12-2011, 11:14 AM   #1
wibas
Question Finishing the area behind the seat??????????
I have a 1952 GMC with a bench seat. I removed the original gas tank from the area behind the seat. What can I use to finish off this area starting at the door latch post arround the back? Pictures would be great. Thanks.
wibas is offline   Reply With Quote
Old 12-12-2011, 11:20 AM   #2
MrTucker
MrTucker's Avatar
Re: Finishing the area behind the seat??????????
what ever you use will have to be custom. I'm not aware of any panels you can buy for this.
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 12-12-2011, 01:27 PM   #3
youngrodder
youngrodder's Avatar
There is a guy on this forum with a 57 (i think) truck. I can't remember his user name but he posted some pics of his interior. I copied them because I'm in the process of putting an interior in my 48. I will be saving this back panel for last.
Here are some pics
You just need to be creative. Do some searches on Google. I have seen where people use ABS panels and heat them to form curves.
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-12-2011, 02:23 PM   #4
OrrieG
OrrieG's Avatar
Here is what I have so far. speaker area in the corners will be built out once I have the speakers. The back panel will be covered with 3/16" plywood. They it will be covered in fake leather to match the seats or complimentary fabric. A covered storage tray will go low and gun rack will be mounted high for guns and fishing poles. My build thread has more detail. If you use the foam it needs to be covered with 2-3 coats of latex enamel paint, the fiberglass resin eats the raw foam!
OrrieG is offline   Reply With Quote
Old 12-12-2011, 04:51 PM   #5
Atomsplitter
Atomsplitter's Avatar
There are a few companies that makes ABS door panels, panels for behind the seats, kick panels and headliners for our 47-55 trucks but they are very expensive. If I remember correctly they come as bare ABS that need to be covered by you.
There's this company
http://www.chevsofthe40s.com/browse/...ruck/330T.html
and this comany
http://www.roddoors.com/pages/chevtrk-4755.html
Atomsplitter is offline   Reply With Quote
Old 12-13-2011, 12:34 AM   #6
mr48chev
mr48chev's Avatar
I have a full width speaker box that sits about 8 inches high now but plan to build in storage along with the speaker boxes this go around. The area behind the seats is too good a place to build storage compartments for the things you take along but need to keep out of sight to waste.
Old 12-13-2011, 12:42 AM   #7
parkwood
parkwood's Avatar
This in a '55...
parkwood is offline   Reply With Quote
Old 12-13-2011, 09:49 AM   #8
wibas
Parkwood what did you make your panels out of? Where does a guy go to find the abs panels that can be formed with heat? The curved part is what is giving me trouble. Great pictures!!!!!!!!!!!!!
Old 12-13-2011, 01:01 PM   #9
oldcouple
oldcouple's Avatar
Just do a google search for abs sheet plastic. Lots of choices.
oldcouple is offline   Reply With Quote
Old 12-13-2011, 02:01 PM   #10
parkwood
parkwood's Avatar
sorry i don't have better pictures, but i was not there while the interior guy was building the panel behind the seat.. i can tell you it wasn't abs, but more like a very heavy black cardboard that is used in interiors... over that i think he glued 1/4'' white foam that is how you get the little step you see around the opening..
I'm going to call him and let him know your questions and i'll get back to you and let you know what he says..
Old 12-13-2011, 03:21 PM   #11
youngrodder
With all of our questions, Shawn will start charging us for his knowledge...ha ha
Your a good man Wayne
Marc
Old 12-13-2011, 10:03 PM   #12
wibas
Hey guys! Keep the info coming. Thanks.
Old 12-13-2011, 10:18 PM   #13
Jemo
I have another really good solution for this that is relatively cheap. I've been using sheets of PVC. I buy 4x8 sheets for about $22 from the local sign shop. I think they're sold in mm thickness and I forgot how many mm's it is but it's about 1/8" thick.
I initially tried heating and curving some leftover 1/8" ABS plastic sheet I had but it just wouldn't bend with my heat gun. I tried a piece of leftover PVC board and it is super easy to bend into whatever shape you want. I also used this PVC board before for door panels.
I don't have any pics yet but will post when I'm finished. Gotta get this wiring finished one day first.
Jeff
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 12-13-2011, 10:19 PM   #14
Jemo
Forgot to say I'm just using a $12 heat gun from harbor freight. Works great and doesn't take much heat to start bending the PVC.
Old 12-14-2011, 12:22 AM   #15
mobileortho
mobileortho's Avatar
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
