Old 12-12-2011, 11:41 AM   #1
savatreatabvr
savatreatabvr's Avatar
1973 C20 454 Noisy Front Suspension!
I only hear it when I'm driving slow and turning in my parking lot, I've checked it all and nothing stands out that could be the issue. Any idea's?
savatreatabvr is offline   Reply With Quote
Old 12-12-2011, 03:33 PM   #2
walkerb
walkerb's Avatar
Re: 1973 C20 454 Noisy Front Suspension!
Whats it sound like?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 12-12-2011, 04:39 PM   #3
savatreatabvr
It rattles, I've heard the exact same noise on other vehicles before but this is the first time for mine.
Old 12-12-2011, 04:55 PM   #4
rwhit57
rwhit57's Avatar
My first guess would be brake calipers. See if you can touch the brake when you hear the noise, if it stops you found it.
rwhit57 is offline   Reply With Quote
Old 12-12-2011, 06:36 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
Check shock absorber (sp?) see if bushing are worn or i the shocks came loose. Also upper and lower arm bushings, take the wheel and see if you can move it.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 12-12-2011, 10:02 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
if it was 4X4 i'd say check the front hub
my 79 does rattle/squeak a bit from the fender mount tab broken at the front drivers cab mount
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-13-2011, 12:47 AM   #7
andrewmp6
The brake dust shields on the spindles can come loose over time and rattle when you move.To rule out most things get under it and lube all the joints and drive it see if its still there in a couple of days.
andrewmp6 is offline   Reply With Quote
Old 12-25-2011, 08:44 PM   #8
masterjohnson
so this means suspension parts never rattle? anyway can i just ignore this for now because you said it is just the brake dust shields as long as i wont be dangerous i can just ignore it for a while. i just have lots of things to do and no time to lube the joints under my truck.
masterjohnson is offline   Reply With Quote
Old 12-25-2011, 11:09 PM   #9
savatreatabvr
Huh?
