12-12-2011, 10:07 PM | #1 |
Body line's just don't match up.
I recently discovered that my driver side lines don't match up. They bed is almost an inch higher on this side while on the passenger side it is perfect. what could i do to repair this i looked back into some older pictures and the same thing was present.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
12-12-2011, 10:11 PM | #2 |
Re: Body line's just don't match up.
check ya cab mount bushing, but it could jus be chassis flex..it it like that on level ground?
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
12-12-2011, 10:13 PM | #3 |
so it could be a collapsed bushing rather than something wrong with the frame or bed.
12-12-2011, 10:30 PM | #4 |
yes...there rubber & break down over time..i'm thinkin it there was something wrong with the bed or frame..it would be lover & not tha cab..i'm no square guru..but that's my thinkin..
12-12-2011, 11:28 PM | #5 |
Odd things do happen this truck is put to it's limits much of the time, what baffled me was that I didn't see any bends in the frame and the bed looked fine to me i didn't even think of the cab.
12-13-2011, 01:37 AM | #6 |
yet the bottom of your pinch seams look like they line up perfectly?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-13-2011, 08:23 AM | #7 |
I just looked it's higher than the cabs
12-13-2011, 09:08 AM | #8 |
Robert Olson Transport
first thing is take that truck on level ground with the wheels pointing straight ahead and see whats up . uneven dirt and wheels turned will cause some flex to give the illusion
12-13-2011, 09:53 AM | #9 |
those pics make it look like you're on uneven ground. ...and it being a long bed makes for more chassis flex anyway.
12-13-2011, 09:54 AM | #10 |
I had the same problem for years. I thought I had frame warp. I run across ditches with it loaded. When I decided to retire it and do a frame off resto, when I got threw I was going to take it to a frame shop to get it fixed. When I put it all back together all lined up perfect. When I took the cab mounts off there was a hand full of rust powder that came out of each one. So I think the mounts were so wore out that it let the cab fall on one side and lifted the other side. I would say replace the cab mounts first. As old as they are they need replacing anyway with not much exspence. This may just fix your problem. To my amazement it fixed mine.
12-13-2011, 01:47 PM | #11 |
I had the same problem with my '74 stepper. I had to replace the cab mounting beams; they were rusted into nothing. Put in all new rubber mounts after replacing the beams and complete rocker panels. Next was new bed mounts and realigning the doors on their hinges. Even with all of that one of my doors still isn't quite square. I think that chevy had something of a problem with quality control for a few of the early years but a little fiddling around should get it straightened out. If not, there's always Bondo . . .
12-13-2011, 05:25 PM | #12 |
I noticed today the culprit is the rear driver side bushing. the rubber is almost gone. i will take care of this when i have a chance. thank you to everyone.
Tags |
bed lines 1985 problem |
