![]() Join Date: Dec 2001
Throttle cable bracket
I am doing the conversion for throttle rod to throttle cable on my '68. What would be a good throttle cable bracket for this?
Edelbrock 1406 carb Performer intake Manual tranny Installing 350/290 hp crate engine Thanks, Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
Re: Throttle cable bracket
I want to hear some of these answers also.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
I'm sorry I don't have a part number for you guys but I do have a picture sort of. I'm 99.9997% sure the piece I used was an Edelbrock piece. I don't have a throttle cable but I do use that hole for the cruise control cable on my aftermarket cruise.
As you can see in the pictures there is a hole for the throttle cable and a hole for the th350 TV cable. I bet if you clicked around on Summit Racing long enough you'd find the part. It had some adjustment in it and is plated the goldish color like some of the linkage on the 1406.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
ttt
1969 Custom 30 wrecker
I'm thinking the stock bracket from the 71/72 Chevy & GMC trucks might work. It's the one that bolts the left rear carb bolt shown in this listing:
http://www.ebay.com/itm/1971-1972-73...item5d315724d5 I'm pretty sure it's the kind I used on my 72 Chevelle/454 project but would have to double check. Here is another type that bolts on with the coil bracket from a 72 Impala that might also work. http://www.ebay.com/itm/1971-1972-Ch...item5d3097bb8f .
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#6 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
![]() Join Date: Apr 2011
I converted my '71 with a 4 speed from a cast iron 2bbl intake to an Edelbrock Performer with a Quadrajet. I tried a few of the charming cheapie aftermarket brackets and didn't like them at all, so I ended up finding a stock throttle bracket for GM car with a q-jet. It attached at the back of the carb on the two rear studs, but it didn't fit right and got in the way of the rear vacuum port on the carb body. I ended up cutting it in half basically, using only the side with the bracket, one stud hole and locating tab, works great and looks like it belongs there. Initially I thought this wouldn't work for you, the 1406 is Edelbrocks version of the old Carter AFB which is a square bore and the q-jet is a spread bore, but if, like Gary asked, your carb has a hole in the baseplate for a locating tab (I think they do) then you can probably do the same as me, just find a stock piece and cut it to fit just the one corner of the 1406.
Grandpa in the rustmobile...
I robbed a throttle cable bracket from a 71 chevy when i convreted to cable peddel.
Its not bolt on.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Thanks for all the ideas.
