Old 12-13-2011, 05:44 PM   #1
XtechX
XtechX's Avatar
Shifter pics?
I put bucket seats from a 2001 F***d F150 in my truck and am about to purchase a center console/seat for in between them. The problem is, that I think the hurst shifter I have now will hit the seat in 2nd and 4th. So I'm looking for ideas to modify the one I have or an idea to make a custom one. Also, buying a new shifter that will work is also an option. So please post 'em if you got 'em.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 12-13-2011, 05:58 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Shifter pics?
The new Hurst bolt on 55-57 Chevy shift handle may do what you want. Part number 5388620, but they're not cheap:
http://www.summitracing.com/parts/HUU-5388620/
Old 12-13-2011, 08:21 PM   #3
XtechX
XtechX's Avatar
Re: Shifter pics?
Thanks for the input Markeb01, you werent kidding ...lol
they aren't cheap considering there just a piece of chrome flat stock! I wonder if I could just cut mine and add a foreward facing curve at the bottom that would be hidden by the boot? That would move the shifter foreward enough, I think??
Old 12-13-2011, 09:07 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Shifter pics?
If you just need it to move forward a couple of inches, an adapter like the one I made might solve the problem, or in combination with bending your existing handle. If they are heated just above the bolt holes until cherry red, they can be bent a generous amount without damage, and the area isn’t seen after the boot goes on.
Post #39 on the following link shows the adapter I made:
http://67-72chevytrucks.com/vboard/s...adapter&page=2
Old 12-13-2011, 09:19 PM   #5
McCoyAZ
McCoyAZ's Avatar
Question Re: Shifter pics?
X:
Can't help you with the shifter since I have an automatic in mine .......
BUT
Tell me how hard it was to put the buckets from the F150 in your truck please??? I have a set of power buckets from an 01 sitting in the garage but the mounting rail isn't flat.
What all did you have to do to make them work?
Details and pictures would be appreciated....
McCoyAZ is offline   Reply With Quote
Old 12-13-2011, 09:23 PM   #6
XtechX
XtechX's Avatar
Re: Shifter pics?
Ya know..I think that is a darn near a perfect fix. Thank you sir...Thats 2 times in 2 days you've helped me figure things out!!! I do appreciate it.
