Old 12-13-2011, 06:13 PM   #1
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
Sick of hunting down this issue on my own - Please Help! :)
So I decided a video would work a lot better in describing the issue I am lost with right now!
I have fully tuned up the truck and I am just plain out f ideas right now...so I am enlisting the help of all my friends on the site!
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 12-13-2011, 06:47 PM   #2
Goldfinger
Goldfinger's Avatar
Re: Sick of hunting down this issue on my own - Please Help! :)
Electric fuel pump or manual? I had an f250 that did this on the rear tank. it was a bad pump.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 12-13-2011, 06:49 PM   #3
Evil Trailblazer SS
It has dual electric pumps and both pumps, pick-up screens, all soft lines, filter, etc. are all new...Does it on both tanks.
I have an extra throttle body on the shelf and even swapping out the TPS and IAC yield no results, it still does this...
Old 12-13-2011, 06:55 PM   #4
Goldfinger
Goldfinger's Avatar
Bad spark plugs. such as to much or to little gap. not enough current bad wires.
Old 12-13-2011, 07:05 PM   #5
Evil Trailblazer SS
The spark plugs were my first thought...like i may have broke the porcelain insilator... But they are brand new NGK replacements gapped to stock specs with brand new MSD 8.5mm wires. All tested out perfect even after re-checking them twice.
I used the NGK-2771 plug as alled out for my truck...
http://www.summitracing.com/parts/NGK-2771/
Old 12-13-2011, 07:19 PM   #6
Goldfinger
Goldfinger's Avatar
But that's odd when its idling it sound like every cylinder is firing but increase the idle and it stumbles almost as if the cylinders are misfiring. I would assume it was a fuel problem but it seems to get plenty. electricity would be another possibility. However air doesn't seem to be an issue. could it be an internal problem like a sticky valve?
Old 12-13-2011, 07:27 PM   #7
Evil Trailblazer SS
Sitcky valve would (or should) get worse with RPM, it nearly clears up before 2,500rpm...And when you let off the throttle, it clears up like a switch has been flipped and everything is perfect almost instantly at idle...
Old 12-13-2011, 07:29 PM   #8
Goldfinger
Goldfinger's Avatar
Are you sure it clears up or could it be masked by a smoother operating speed.
Old 12-13-2011, 07:33 PM   #9
Evil Trailblazer SS
It does have a slight miss at upper RPMs but its not debilitating like it is from 1,000-2,000
Old 12-13-2011, 07:41 PM   #10
Goldfinger
Goldfinger's Avatar
It almost sound like a faint tink at idle. could it be a loose lifter prior to the point at which it hits the ticking sound.
Old 12-13-2011, 07:47 PM   #11
Evil Trailblazer SS
I highly doubt it...the way it switches in and off with throttle, it's not likely a lifter...
Old 12-13-2011, 07:48 PM   #12
Goldfinger
Goldfinger's Avatar
I'm all out of ideas
Old 12-13-2011, 07:51 PM   #13
Evil Trailblazer SS
Maybe a 454HO crate and Howell EFI unit will fix it...
Old 12-13-2011, 07:55 PM   #14
68Timber
I know the pieces fit
68Timber's Avatar
What kind of exhaust is on the truck? More specifically, does it have the original cat?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-13-2011, 07:57 PM   #15
Goldfinger
Goldfinger's Avatar
I'd say a new motor would fix it, how many miles does it have and has it been rebuilt?
Old 12-13-2011, 08:03 PM   #16
Evil Trailblazer SS
The truck has 52,500 on it...it's verified. But last week I found the GM Reman decal plate on the side of the block, so I have no idea how many miles are on the engine. It's a .030" over 454 now...so 461.
Old 12-13-2011, 08:06 PM   #17
Goldfinger
Goldfinger's Avatar
when did it appear?
Old 12-13-2011, 08:11 PM   #18
Evil Trailblazer SS
The exhaust does have a newer aftermarket cat, not the original...
The stumble issue has been present since I brought the truck home. I spent over a month correcting everything, tuning it up, replacing vacuum lines, fixing all the wiring problems, etc. The truck would not idle down below 1,600 when I picked it up and it ended up being the coolant sensor for the ECM having really crappy splice connectors that broke and corroded.
Old 12-13-2011, 08:45 PM   #19
1LowToy
I'd pull the codes and see what you have going on. I'd take a close looke at cap and rotor for arcing or other defects. It also sounds like it's leaning out as it lowers rpm which may be the stumbling problem. Where is the O2 sensor located? Are there mufflers on it at all? Exhust system back pressure may also be an issue.
1LowToy is offline   Reply With Quote
Old 12-13-2011, 11:54 PM   #20
Evil Trailblazer SS
That is the strange thing, the ADLD connector seems to be dead...I get no response when I jumper the pins...I am really not liking the hack work performed on this truck in the distant past! >
The new o2 is in the stock location of the driver side manifold and the exhaust is stock y-pipe and 3" Catco converter with a 14" case 5x8 Magnaflow split to dual 2 1/2"...it's how the truck was done when I bought it.
Old 12-14-2011, 02:14 AM   #21
irishman999
irishman999's Avatar
Hello from Reno, if your sure the fuel delivery is good and want to check the ignition I have an extra HEI distributor you can slap on if you have doubts about your ignition. Let me know.
irishman999 is offline   Reply With Quote
Old 12-14-2011, 02:42 AM   #22
Desert1957
Desert1957's Avatar
Check the top bushing in the Distributor, Iv'e had a lot of 454's go bad. Take the Dist cap off and wiggle the rotor , If the top shaft has ANY play, that's whats wrong. Higher RPM's seem to make it spark scatter.
Desert
Desert1957 is offline   Reply With Quote
Old 12-14-2011, 02:58 AM   #23
lha1992
lha1992's Avatar
I had a problem with my '89 C1500 with the 350TBI where it would idle sort of yet it would increase and decrease increase and decrease in idle. But when you would give it a little gas it would stay constant. Though as you would increase the RPM as it got past 2800 and 3000 it would stumble and the RPM would go up and down.
I had change the TPS, distribitor cap and rotor, spark plugs/wires, fuel filter. Nothing changed it. Turned out it was the fuel pump. Had low PSI at idle yet good PSI when you gave a little gas but at wide open throttle it sucked.
The pump was the original pump in the truck and my mechanic said it should have gone out 10 years ago haha.
lha1992 is offline   Reply With Quote
Old 12-14-2011, 03:16 AM   #24
craazy22
craazy22's Avatar
Check the dist. and the rotor with out cap for play. I just finish rebuilding my 454 and it was doing the.same thing due to bad shaft
81 chevy stepside 6.0/t56 swap in progress....
81 chevy silverado k5 2wd 350 tpi and 700r4.. SOLD
07 chevy colorado "work truck" SOLD
02 chevy silverado z71 off road package
craazy22 is offline   Reply With Quote
Old 12-14-2011, 11:20 AM   #25
Evil Trailblazer SS
I will surely let you know! Thank you for the offer!
Desert
I will check this out ASAP...
Since both pumps and all related parts of the fuel delivery system are new, I doubt this is the case. The truck is getting plenty of fuel at idle, we think it may possibly be getting too much...we are going to check some things out and I will report back.
That makes three that say it may be the distributor. I will check it when I get a minute...
