Old 12-13-2011, 06:23 PM   #1
okieraptor
okieraptor's Avatar
found a 6.0. need to make sure im getting everything.
Its out of a 05 2500. I know i need the unmolested wiring harness and ecm as well as the gas pedal. Is there anything else i need from the donor truck to slap this in my square?
Ill be using my 700r4 so i dont need anything tranny wise.
Thanks Okie
82 chevy longbed(grey truck)first truck when i was 15!
okieraptor is offline   Reply With Quote
Old 12-13-2011, 07:10 PM   #2
harnalien
TruckincrazY
harnalien's Avatar
Re: found a 6.0. need to make sure im getting everything.
Well if it's a Drive By Wire throttle body, you'll need to figure out how to hook up your TV cable from the 700.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 12-13-2011, 08:05 PM   #3
okieraptor
okieraptor's Avatar
Ah i forgot about that. Got any ideas on how to do that?
Old 12-13-2011, 08:51 PM   #4
harnalien
TruckincrazY
harnalien's Avatar
I couldn't find any viable options when I was doing mine, so I had to switch to a cable throttle body. My 700 is toast now, so that was a waste of time. Others have had luck, so who knows. Anyway, I am unaware of any options to hook up a 700 to a DBW throttle body.
Old 12-13-2011, 09:34 PM   #5
okieraptor
okieraptor's Avatar
Ok thanks for the info.
Old 12-17-2011, 12:05 AM   #6
Bigo Serge
I would use the transmission from the donor truck. You will be a whole lot happier with the electric shifting trans, since the harness is all there. If you need any work done to your computer or harness I HIGHLY recommend John at Speartech.
Pick'em up, lay'em down, Oh Yeahhh
Bigo Serge is offline   Reply With Quote
Old 12-17-2011, 02:27 AM   #7
okieraptor
okieraptor's Avatar
I would but the 4l80 is gone already. My buddy that is the manger said the owner sold it out the xay thsy got it for 500$. Wish i could have been that lucky guy!
Old 12-21-2011, 01:20 PM   #8
duwem
duwem's Avatar
The ealier drive by wire engines needed a TAC (throttle actuation control) module but the later ones this might be built into the ECU???
duwem is offline   Reply With Quote
Old 12-21-2011, 02:04 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
05 is usually the switching point. Trailblazers in 05 got the new pcm which ran directly to the TAC Pedal, other 05 vehicles would still have a TAC module and pedal.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-21-2011, 03:12 PM   #10
ls1nova71
ls1nova71's Avatar
On full size trucks 2007 is the last year they had a TAC, and that is only in the OLD body style (or Silverado Classic I think they called them) '07's, the NEW body style '07's don't have them.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
