Old 12-13-2011, 07:06 PM   #1
64shortc10
64shortc10's Avatar
Something draining my battery?
I bought my 66 and have been upgrading things like the altanator. Voltage regulator, battery and cables. Cleaning up some of the wiring. And I can jump start my truck and drive it all around but when I come out the next day my battery is dead. Any common issues on these trucks I should look for?
Thanks guys
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 12-13-2011, 07:16 PM   #2
dmwphoto
dmwphoto's Avatar
Re: Something draining my battery?
put a test light between the positive cable and positive battery terminal (unhook the positive cable) and then pull fuses one at a time until you find the circut that is causing the draw.
dmwphoto is offline   Reply With Quote
Old 12-14-2011, 02:04 AM   #3
NorthstarGMC
could be a loose ground on the charging system that isn't charging your battery.
1963 GMC Wideside powered by a LH2 32v Northstar
NorthstarGMC is offline   Reply With Quote
Old 12-14-2011, 10:41 AM   #4
1963c-10
1963c-10's Avatar
Did you unhook the battery before you installed the voltage regualtor? Very easy to short it out if you installed while battery hooked up. Could be the case why you can jump it and it'll run, but not recharging.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-14-2011, 04:18 PM   #5
64shortc10
64shortc10's Avatar
Thanks guys I will try the light tester and battery trick by pulling the fuses one by one! I did install the voltage regulator with no battery hooked up. It seems like the battery is getting charged while it is running. By something is draining it over night. Thanks again. I'll keep trying.
Tony from Norcal
Old 12-14-2011, 04:27 PM   #6
1963c-10
1963c-10's Avatar
Yeah, your going to have to start poping fuses.
Old 12-14-2011, 07:49 PM   #7
Bazooka
Keepin it old school
Bazooka's Avatar
When using the testlight method if you havent found the problem after pulling the fuses one by one try unhooking the wire from your horn relay to the horn and see if that turns off the testlight. I had a horn relay go bad on me once and caused this problem. Drove me nuts for days till I figured it out. I also had the same problem on a different vehical it was a faulty voltage regulator..
Bazooka is offline   Reply With Quote
Old 12-14-2011, 07:51 PM   #8
dmwphoto
dmwphoto's Avatar
/\ /\ good advice
Old 12-14-2011, 07:54 PM   #9
brokenspoke
brokenspoke's Avatar
Bad battery?
brokenspoke is offline   Reply With Quote
Old 12-14-2011, 07:55 PM   #10
dmwphoto
dmwphoto's Avatar
Originally Posted by brokenspoke View Post
Bad battery?
seriously doubt that, but it is possible. Some circut is staying powered. need to locate and fix.
Old 12-17-2011, 07:05 PM   #11
dmwphoto
dmwphoto's Avatar
update?
Old 12-18-2011, 10:14 PM   #12
Martin64
Martin64's Avatar
I had a '69 with a bad horn relay that was draining the battery. It wasn't until the horn stuck on that I found the problem. As soon as I disconnected that relay the battery drain stopped.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 12-19-2011, 08:53 PM   #13
old cruiser
old cruiser's Avatar
Horn relay gave me some grief as well
old cruiser is offline   Reply With Quote
