Cluster swap
Hi you guys im new to the site and i have a 86 custom deluxe swb. it was a v6 auto to start with then was turned into a 5 speed, and now i own it and has put a 1969 327 v8 and a turbo 400 transmission. The truck came with the light up gauges, and I have a cluster with the manual gauges from a 82 swb and i was wondering if it was a straight swap or if i will have to do some wiring to make it work
Re: Cluster swap
From what Ive read you have to re-pin the cluster conecter plug and install sending units.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Re: Cluster swap
Do you know where i could get a diagram on which ones to switch?
78K & 79C Jimmys
Re: Cluster swap
i just changed from idiot lights to factory gauge/tach
check my 78 jimmy out below.....
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
