Old 12-14-2011, 10:43 AM   #1
Go5.3tt06
4x4 driveshaft
On my 84 k10. It's lift 8" superlift. I run sm465 transmission and transfercase is np205. The yoke is flat flange. So I tried out driveshaft on front axle. It's seem too limit. I did grind all lips the cv. It seem little ok but I can feel it could break one day. Is there way for me find a simple and cheap to get this fit right for lift size. Let me know.
Go5.3tt06 is offline   Reply With Quote
Old 12-14-2011, 10:50 AM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: 4x4 driveshaft
Simple, yes. Cheap, no.
http://www.highangledriveline.com/
Jesse will hook you up, and you will never have issues again.
Dunenutt is offline   Reply With Quote
Old 12-14-2011, 10:53 AM   #3
Go5.3tt06
Re: 4x4 driveshaft
How much it would be?
Old 12-14-2011, 04:57 PM   #4
Dunenutt
Newbee
Dunenutt's Avatar
Re: 4x4 driveshaft
$400 - $600 ?
I just had a rear one built locally for around $600, but mine is alot lower than yours.
Old 12-14-2011, 10:41 PM   #5
Mr. 250r
Mr. 250r's Avatar
Re: 4x4 driveshaft
Or.... http://www.4xshaft.com/, but probably expensive im also getting mine built locally for under 400$ total and a little longer than a stock 4wd suburban driveshaft since im converting to a 205 and using 1410 u-joints but not a flange
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 12-15-2011, 06:22 PM   #6
76stepsidechevy
Re: 4x4 driveshaft
I just had a rear shaft made by tom woods for 260 shipped. I only have a 4 inch lift but also have the 465/205. He does high angle stuff if you need it also.
76stepsidechevy is offline   Reply With Quote
