12-14-2011, 11:15 AM | #1 |
So where do i go from here.....
I am like a lot of other people. I can't just leave a good thing alone, im American, we build stronger faster, custom....
I have this '78 one ton 2wd. But what I under stand, there is not much you can do to the one tons as far as keeping it 2wd and lowering with any kit? Ive started contemplating making it 4wd and putting a Dana 60 under the front. Im just need help with that if that is the road i decide to take. But as far as keeping it 2wd, what can i do to it? It has the 14 bolt FF axle under the rear end, so keep that in mind as far as wheels, lowering and etc. I just need some help finding a good direction. |
12-14-2011, 11:23 AM | #2 |
Re: So where do i go from here.....
If you stay 2wd I would convert it to half ton. But if you look at my sig you will know my vote goes towards a conversion and a lift!
Posted via Mobile Device |
12-14-2011, 11:24 AM | #3 |
By the way, that truck is CLEAN
12-14-2011, 11:31 AM | #4 |
It followed me home?
Bell tech and western chassis both make spindles and springs, w.c. sells a flip for the rear too. 8 lug wheels are harder to find in a 2wd look but they are out there
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
12-14-2011, 03:14 PM | #5 |
Prerunner!
That thing would look bad-ass with a wheel/tire change, new mirrors, and a nice roll bar in the bed. Wouldn't take a lot of work since it already sits up pretty high and wouldn't be very expensive (unlike converting to 4WD). It would be different from most of what you see on here and would be very usable as a parts hauler and runabout. |
12-14-2011, 03:57 PM | #6 |
Garage wrench
I would get a dually rear axle, dually front hubs and slam it. Maybe air, maybe static suspension drop.
Something like these....
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
12-14-2011, 10:54 PM | #7 |
if your gonna 4wd is possibly unless you can find a D60 cheap which isn't really possible just get a 10bolt if your not doing any off-roading there's no point put the money else where like towards a lift or the axle conversion or wheels and tires
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
12-15-2011, 10:10 AM | #8 | |
12-15-2011, 10:27 AM | #9 |
I think it's gorgeous the way it is!!!!!!! But, if you want to change it up a bit...1. Put a chrome bumper on the front. 2. Remove the side trim. 3. Put the smaller chrome mirrors on both doors. 4. Find some COOL 8 lug wheels YOU like and some bigger tires Don't drop it, you don't even have to 4X4 it. Just make sure it has a good Posi. Enjoy
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
12-15-2011, 01:31 PM | #10 |
That truck is a beauty. If you are looking to go in a different direction, a good first step might be to trade for an truck that is well suited for whatever you have in mind. I suspect you would get some good offers. Might get a good portion of the work done without having to use Gojo.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
12-15-2011, 01:59 PM | #11 |
Polished 8 lug slot mags and a mirror swap would look great on that truck.
12-15-2011, 02:56 PM | #12 | |
12-15-2011, 03:26 PM | #13 |
I think it would look awesome with some H2 wheels and a mild lift. Its too clean to 4-wheel so just find yourself a beat up 4x4 instead of spending the $$$ on this one. Or if you want a 2wd just find a cheap 1/2T and roll that.
12-15-2011, 04:02 PM | #14 | |
12-15-2011, 04:42 PM | #15 |
Should i just take the mirrors off and leave filler bolts in place and not have any mirrors, or should i have one some circle one on top of the door. Im asking because that was what i was thinking about today.
12-15-2011, 05:57 PM | #16 |
Personally, I wouldn't want to drive one of these big trucks without mirrors. Backing up these wide loads is tough enough as it is. I've also heard from other guys that have the small round mirrors that they are worthless. Look cool, yes, but not so much with the functional.
12-15-2011, 08:34 PM | #17 |
I'd leave it as is, personally. That's a total time machine. If you're set on changing it, I'd 4x4 it. The base models just beg to be jacked up.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
12-16-2011, 02:58 PM | #18 |
These would look great on your rig. Period correct too http://67-72chevytrucks.com/vboard/s...d.php?t=496898 Here is my C20 with the same rims/smaller tires (10.5's) David
12-17-2011, 01:05 AM | #19 |
x2
1986 Chevy Wrangler 4x4 305/700r4 6" lift 37x14.50x15 |
12-17-2011, 06:50 PM | #20 |
lower it put nice wheels on it and drive it
