Old 12-14-2011, 11:48 AM   #1
C-10 simplex
Dual wheel conversion:
Would adding dual wheels to a 3/4 ton, or single rear wheel 1-ton put any undue stress on the rear axle---specifically the drum/mounting flange/axle bearings/studs etc.?
i don't know if the 3/4 has the same rear axle as the 1-ton---full float or semi float?
C-10 simplex is offline   Reply With Quote
Old 12-14-2011, 02:18 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Dual wheel conversion:
What year 3/4 ton? IIRC, they switched from the 14 bolt FF (same as 1 tons) to the 14 bolt SF sometime in the late 70's.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 12-14-2011, 10:40 PM   #3
C-10 simplex
Let's say 82-87.
Or 88-97ish.
Old 12-15-2011, 08:24 AM   #4
BigBlocksRule
Doesn't really matter...any 8-lug rearend will handle a lot more than what you're talking about doing. The semi-floater actually has bigger axle shafts, 33 spline honkers.
BigBlocksRule is offline   Reply With Quote
