Back-up lights
My '64 did not come with factory installed backup lights. Were these an option? I've seen them on other trtucks even earlier years. I'm curious to learn more about them.
I'm not sure it is all that important to me to have the correct lights especially beings I would probably have to put a toggle in to make them work (not sure if trans is equip'd with a backup/reverse switch to power the lights. I like the look of the single 4" spot as an alternative. I was wondering if anyone has examples or other suggestions.
1947 Art Deco Chevy truck 1964 C20 Custom cab 1965 Tempest Wagon 1967 GTO 1972 Luxury Lemans http://www.cardomain.com/id/a67goatnut |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Back-up lights
I think they were an option, 1966 they were required. you have a nuetral saftey switch you probably have the reverse light switch.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Jun 2011
Re: Back-up lights
64 and 65 it was an option.in 66 it was manitory same with seat belts
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
Re: Back-up lights
I know they were an option on GMC trucks in 1960 and according to the sales catalog they could be fitted to all transmissions with a switch. see picture.
http://s1299.photobucket.com/user/jb...23904108567829 |
Re: Back-up lights
Reverse lights have been optional since the late 40s-I added them to both my 64s, I'm getting too old-- need them to back up w/o hitting things.
![]() Join Date: Nov 2010
Re: Back-up lights
Does anyone know where you can get a new reverse light switch? mine went bad on me..
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Back-up lights
Reverse switch for an automatic or 3 speed manual are the same on the steering colum for a truck or car. The 4 speed switch is hard to come buy. There was a kit from GM for reverse lights.
![]() Join Date: Sep 2011
Re: Back-up lights
I picked up an new column shift NOS one from Ebay a couple of weeks ago. Great deal on it!
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
Re: Back-up lights
I have a 3 on the tree. Ill have to look on ebay.
Re: Back-up lights
Switch is right in the middle of this picture.
1963 ![]() 4 speed installation ![]() Last edited by aerotruk63; 12-14-2011 at 08:12 PM. |
Re: Back-up lights
is this everything you need to add back up lights to a 65? i really want to do it right.
Re: Back-up lights
There is an Accessory Installation Book you can buy which details the installation and shows you where everything goes and where to drill when necessary. These books are great when scrapyarding to get all the pieces needed. The rubber wedges in the picture are for 60-65 stepside. 66 had an embossment in the stepside fender.
#13 |
Re: Back-up lights
thanks im looking for the fleetside. i have that book for the 65 i will look. thanks again
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 12-14-2011 at 08:30 PM. Reason: add |
#14 |
Senior Enthusiast
Re: Back-up lights
#15 |
Re: Back-up lights
I wish i could pull stuff out of the picutre
#16 |
Re: Back-up lights
WOW, Great stuff!
I will have to look for and purchase one of those acc. install books. Aerotruck63, If it would not be to much to ask, in the meanwhile could you possibly scan the pages for the Auto trans switch install? Thanks for the help everyone!
#17 |
Re: Back-up lights
Goat, sent a PM.
Jake
#18 |
Re: Back-up lights
#19 |
Re: Back-up lights
Is the locating template that is shown in the above pics from the accessory manual available? If not, someone should make them to assist in the installation.
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
#20 |
Re: Back-up lights
corvettejim1968, Thanks for posting the install info. I really appreciate it!
#21 |
Re: Back-up lights
OK, I'm closer to having backup lights. I found a complete set of originals that I will be installing. I have searched around for a switch but all of the switches that I have found have four spade connectors.
Any help locating a two connector switch would be appreciated.
#22 |
Re: Back-up lights
I put Wagner #795 bulbs in my back-up lights-they are designed for rotating beacons(like a firetruck light), 50 watts. The lens is glass, housing is metal & I have not noticed any issues. I thought I might add a relay, but so far the OE switch works fine, no longer than you usualy reverse-might be an issue if you back up more often(trailering), but adding a relay up under the column would be simple enough. I did rebuild the OE harness & used green 14ga wire, and grounded both lights using a wire to the frame.
#23 |
Re: Back-up lights
Would anybody have the measurements of these back up lamps?
I'm still searching for what to use on a custom job for a O.T. vehicle. Close up pics would be great too! Thanks!
"I feel the need for speed!"... as soon as I am done with my nap. |
#24 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Back-up lights
Here's a thread on topic for chad64chevy.
I typed in the Google box above; backup lights template
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#25 |
Re: Back-up lights
I guess I'll have to make one in CAD
