Old 12-14-2011, 06:47 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Using a 87-91 Tank and Pump for my Suburban
Just checking to make sure, but I'm about to purchase a 91 suburban tank and going to use it under my 72 Suburban and the in tank fuel pump for my 5.3.
Any concerns on this setup?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 12-14-2011, 11:40 PM   #2
72gmcshorty
72gmcshorty's Avatar
Re: Using a 87-91 Tank and Pump for my Suburban
just make sure you get the correct pump...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 12-14-2011, 11:43 PM   #3
5150
C10 Club Tennessee
5150's Avatar
Is there a wrong one? Will the factory one not suffice?
Bryan
www.gmtruckshow.com
Old 12-15-2011, 01:01 AM   #4
clinebarger
The stock 87-91 pump WILL NOT work, I run a 95 Impala SS pump in my 90 model Suburban tank that is in my 85 Suburban, Be sure to use 5/16" fuel injection hose between the pump & sender......The TBI hose WILL explode cause a massive fuel leak in the tank.
clinebarger is offline   Reply With Quote
Old 12-15-2011, 02:05 AM   #5
Mr. 250r
Mr. 250r's Avatar
Don't alot of people run the walbro 255?
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 08-18-2012, 09:50 AM   #6
5150
C10 Club Tennessee
5150's Avatar
Any other recommendations for fuel pump? Definitely plan on using the 91 tank, in other applications other then the 95 Impala? What do the specs need to be for the flow rate and the PSI to work in the 5.3?
Bryan
www.gmtruckshow.com
Old 08-18-2012, 10:49 AM   #7
AJII
AJII's Avatar
TBI is about 15psi...LS motors need about 50.
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 08-18-2012, 02:28 PM   #8
ls1nova71
ls1nova71's Avatar
Ls engines run at 58 psi. I've used TPI pumps in the past but they only are supposed to put out 45 psi or so, probably about what the Lt1 pump from the Impala runs.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-18-2012, 06:26 PM   #9
clinebarger
The LT1 pump works great, It can make up to 100psi when "dead headed".
It's also fine up to 450 HP, I dont know the flow rate.
LT1's & 5.3's have very simular HP/TQ numbers.
Old 08-18-2012, 06:30 PM   #10
5150
C10 Club Tennessee
5150's Avatar
clinebarger, after I updated this post, I saw where you recommended an ACDelco one on ebay. I just bought that one.
Bryan
www.gmtruckshow.com
Old 08-18-2012, 11:38 PM   #11
ls1nova71
ls1nova71's Avatar
I wasn't saying it wouldn't work, just stating about what pressure they're supposed to run at. My two cars with TPI pumps are both running true LS1's that put out over 300 hp stock. The pumps work fine, but people say you shouldn't use them. They are both AC Delco pumps. One car has over 120k on it and the other has 66k, so by my calculations they work great.
Old 08-19-2012, 06:02 PM   #12
clinebarger
I wasnt singling you out bud....Just commenting. I know you know what your talking about.
Ive heard to same thing about these pumps, Which is completely unfounded.
The Gen 1 Vortec CPSFI engines are regulated at 60-66psi & use a identical pump as the TPI/LT1 pump. Ive also cut open several LS1, LS-truck, LT1 & TPI pumps ALL identical number of vanes, Rotor height also the same.
The Walbro 255 pump is also the same Except has a 3/8" outlet vs. a 5/16" outlet on factory pumps.
The low pressure TBI pumps have fewer vanes & max out at about 55psi (dead headed)
Old 08-23-2012, 09:58 PM   #13
5150
C10 Club Tennessee
5150's Avatar
Okay, one last question. I got my pump in today and when I cracked open my "91" gas tank, there was no pump in the tank.
My question is will an "actual" 87-91 pump fuel assembly fit in the tank and work properly?
Bryan
www.gmtruckshow.com
Old 08-23-2012, 10:38 PM   #14
ls1nova71
ls1nova71's Avatar
The '87-'91 sender will fit the tank if the tank has the big sender, roughly 4" in diameter, but if it's not an actual '87-up tank it probably won't have the baffeling to keep the fuel around the pump when the tank gets low.
Old 08-23-2012, 11:20 PM   #15
5150
C10 Club Tennessee
5150's Avatar
I'll have to measure the sending unit outlet. It's one of real big tanks, but I'm not sure what year they had those big tanks.
Bryan
www.gmtruckshow.com
Old 08-24-2012, 08:45 AM   #16
5150
C10 Club Tennessee
5150's Avatar
Ok, I found something out about the tank. It was given to me by another board member. He told me that it came out of an 88 suburban, but it was a diesel.
Bryan
www.gmtruckshow.com
Old 08-24-2012, 06:24 PM   #17
clinebarger
The tank may still be baffled? I dont see why GM would make 2 different tanks, But make sure first....A 40 gallon tank NEEDs baffling for a in tank pump.
Old 08-24-2012, 07:17 PM   #18
5150
C10 Club Tennessee
5150's Avatar
Stupid question alert, how can I tell if it's baffled?
Bryan
www.gmtruckshow.com
Old 08-24-2012, 09:06 PM   #19
clinebarger
The tank will have "divider" walls running top to bottem within the tank.
Not just a hollow tank.
Old 08-29-2012, 09:45 PM   #20
5150
C10 Club Tennessee
5150's Avatar
It is not baffled, sucks, I had been planning on using that tank.
What about the 88-98 burb tanks? I'm not sure what shape they are in.
Bryan
www.gmtruckshow.com
Old 08-29-2012, 11:53 PM   #21
clinebarger
Square body Suburbans ran from '73 to '91 The next body style "GMT-400" Suburban ran from '92 to '00, For a 67-72 Suburban....I would use a 87-95 G-series van tank.
Old 09-06-2012, 11:50 AM   #22
5150
C10 Club Tennessee
5150's Avatar
Found a 93 at the pullapart. Are you certain the 93 tank will fit? I know the straps are different, but I can figure something out.
Bryan
www.gmtruckshow.com
Old 09-06-2012, 07:26 PM   #23
clinebarger
A '93 G-series Van tank? Its been a while, May have to trim the frame rails a little, Van tanks also come in different sizes, So measure first.
Old 09-06-2012, 11:42 PM   #24
ls1nova71
ls1nova71's Avatar
Every pull-a-part around here punches a hole in the tank to drain them. You're lucky yours doesn't, makes finding a tank that will fit alot easier.
Old 09-07-2012, 12:01 AM   #25
5150
C10 Club Tennessee
5150's Avatar
Oh no, they do here to. I can get it repaired though.
Bryan
www.gmtruckshow.com
