12-15-2011, 07:41 AM | #1 |
harness connection issue
Puttn a tilt coulmn in a 69 truck and the turn signal switch 1/2 moon or C style connector want mesh together like all the ones in the past have! Am I missing something here, dont want to slice and dice the connector. The coulmn is from a 72 but I thought all connectors where the same.
any imput would be helpfull as I scratch my head!lol
Things happen for a reason! |
12-15-2011, 05:20 PM | #2 |
Re: harness connection issue
I belive I will change out the plastic connector on the tilt column for the connector that wa on the reg.one that fit.....
12-15-2011, 06:27 PM | #3 |
Active Member
I thought they were all the same also. Can you post a pic of the difference?
12-15-2011, 08:23 PM | #4 |
the turn signal switch for a 71-72 tilt column is different than a non-tilt 67-72. At least there are 2 different part numbers according to LMC pg 155.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=155 I don't know what the difference is, but I'd think if you splice the old connector in to the new switch matching the wire colors you should be fine? |
12-16-2011, 09:32 AM | #5 |
Project Junkie! Fishing Poor!!
The connector should be the same. Got pictures? WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-16-2011, 05:49 PM | #6 |
The connector on the tilt was different then the non tilt, so I swapped the connector out and we are in buisness!!! Thanks guy's I just needed to step back and look at this a minute!lol
