12-15-2011, 12:38 PM | #1 |
My 72 is dead...
So I took my 12 year old son out into the orchard to let him have a little fun trying to drive the truck around. It was his first time driving a standard. We were having a ball until he had to stop and forgot to push in the clutch.
When we went to start it again it was dead.... No power anywhere. Hooked up the jumper cables and still nothing. Any ideas on where I should start? Thanks |
12-15-2011, 01:05 PM | #2 |
needs more $$$
Re: My 72 is dead...
Check the cables from the battery...if you're not getting power anywhere, I would think something came loose or is severly corroded.
1970 2wd Blazer |
12-15-2011, 01:09 PM | #3 |
X2 check the grounds and are'nt you waiting a little long to let your son drive? He is 12 after all. Great times I miss them a lot with my kids
12-15-2011, 01:10 PM | #4 |
Check those and check the wire that goes from the junction stud by the battery across the core support and around into the cab. There is a fuseable link or should be one right close to the battery and that may have blown or battery acid may have eaten the connection on it like it did on mine a while back.
If you have a good test light test across the battery posts to make sure the battery is charged. Then check from the + post to a good ground on the engine to see if you have a circuit there. keep testing until you find where the power stops. It may just be a loose cable as TubbedII said as quite often they will jar loose. A volt meter can tell you if you have a big voltage drop in the line due to a resistance like corroded terminals or a corroded connection too. |
12-15-2011, 03:58 PM | #5 |
Grandpa in the rustmobile...
i was going WOT throttle bounching thru the field a few years ago in my grandmaws original 53 chevy, broke the taililight and learned to shift 3spd
Id start with grounds to
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-15-2011, 05:24 PM | #6 |
He's driven before but only the automatic. This was his first real test. I'll check the grounds and stuff.
Thanks |
12-15-2011, 06:05 PM | #7 |
Orchards are full of trees. You are a BRAVE man!
12-15-2011, 06:11 PM | #8 |
Regardless -- let him help you fix it if you know what I mean.
X4 (?) on the ground situation .. were you guys bouncing around pretty good? When you hit the starter it won't even grunt? Dead cell in the battery maybe? Maybe pull the battery and take it by Autozone (or similar) and have them check it for you.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
12-15-2011, 07:42 PM | #9 |
Also check the main harness connection at the fire wall.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-19-2011, 12:00 PM | #10 |
Thanks for the suggestions... There was a fuseable link on a small wire from the battery that must feed the main power to the fuse box. My son paid the $4.00 to replace it and now we can go give it another shot. He wasn't going fast enough to hit any trees but he certainly likes to talk about it.
12-19-2011, 12:33 PM | #11 |
I had a battery cable corrode completely through inside the clamp. It was the type shown below, where you can't see the cable-to-terminal connection. Give your cables a good tug and see if one of 'em doesn't come apart.
