![]() Join Date: Nov 2006
22 x 10 w/ 5" bs fit
will a 22 x 10 8 lug rim with 5" backspacing
285 45 22 tire -11.2 wide -31.9 tall tuck in the front fenders of a 67 - 72 truck 2wd. i have a 70 and a 72 i know the front track is a little different because of the disc brake but will it fit either truck???? need help soon trying to get these rims this weekend.....from CL thanks Last edited by duceducenine; 12-15-2011 at 07:26 PM. |
Re: 22 x 10 w/ 5" bs fit
A 10" rim is really 11" lip to tip so you ar looking at 6" of wheel outside the hub face. Then you have at least 1/4" of tire bulge. Take a wheel off and drop a plumb bob off the inside edge of your fender. Now take a tape measure and measure 6 1/4" out from the hub. The distance past the string is minimum how far out the fender the tire will be.
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
If it was an 8" wide wheel I would say yes.
Being an 8 lug axle may throw things off compared to most with half ton axles. How wide is it?
not a good idea
It would be like bolting on a 15x8 ralley wheel (up front) with a 1" spacer behind it.
It's not going to happen.
well right now i have 16.5 x 10
with a 4" bs on my 70 c20 6" from hub to wheel edge.... |
I have a set of Intro Pentia 20x10 with a drop in the front but have 275s and I would not do it again. This is on a 72. Do not rub but are too close for comfort and if you want to really "tuck" them it isnt going to work right. I also have 5 inch BS.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
nobody with pics?
I took mine off and am sending them to get rehooped down to 8.5 because they just didnt really work period. Otherwise I would take a picture and you could see what I mean. The outside of the rim and tire were where the lip of the fender should be. I love the idea of having all that wheel in the front but with a 5 inch backspacing mine did not work well enough to keep that way
thanks for the info i guess i'll leave them
alone dont need more parts i cant use..... |
