Old 04-22-2003, 03:49 PM   #1
lotik
drag it like you stole it
my truck is really slow.
its a brand new crate 350. holley dominator intake, edelbrock 600cfm carb, summit block hugger headers, and turbo mufflers.
the damn thing wont even burn the tires. i have the stock '67 rear end. and a 700r4 trans. i dont have my kickdown cable hooked up yet either. i figured i would atleast get a little squeal.
could it be the timing, or do i just not have enough motor?
by the way i have 20 inch rims on it.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 04-22-2003, 04:00 PM   #2
Smooth68
Smooth68's Avatar
What is your gear ratio?
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 04-22-2003, 04:01 PM   #3
JHickson6
I Love This Stuff!
JHickson6's Avatar
hmmm, too much body filler? lol jj, 20's do have a lot of rotating mass but you should still be able to let 'er loose. Uh, what's the width of those rear tires is it possible it's just hooking up real nice? Maybe you could take it to a weigh station and get her weighed, and see is she needs a diet? LOL Can you do a breakstand? what's the stall on the convertor, check to see what your tach says when the tires finally start spinning during the breakstand. I can't think of much right now, where's everyone else?
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 04-22-2003, 04:06 PM   #4
lotik
i have no tach in the truck. i guess a brakestand is the same thing as powerbrakeing? i havent attempted thet yet. and i have no idea what the gear ratio is. how can i find out?
Old 04-22-2003, 04:06 PM   #5
67_SS396
You have to have your TV cable hooked up on the 700 or you will burn it up quite quickly. If not, you won't have enough line pressure to get the fluid flowing, in turn turning your new 700 into a boat anchor.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 04-22-2003, 04:09 PM   #6
lotik
that would not be good. =/
Old 04-22-2003, 04:24 PM   #7
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Isn't it if you put a mark on your driveshaft spin the rear wheels one revolution and count the number of times the mark on the driveshaft goes around.
IE: if the mark goes around 3 and 3/4 times, its most likely a 3.73 gear ratio. I'm not sure tho, I tested on mine when I had the box off and it worked (I knew it was a 3.73, just wanted to see if the theory was correct) But still, that may have been a fluke...can anyone back me up here?
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 04-22-2003, 04:39 PM   #8
>X<
registered IWATA user
>X<'s Avatar
Lotik, who cares if it runs 30's in the quarter, it lays body, thats enough.
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 04-22-2003, 04:40 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Spin it twice in gear.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-22-2003, 04:59 PM   #10
lotik
sean, yeah but i wanted to burn the tires while i dragged the body down the street.
Old 04-22-2003, 06:53 PM   #11
minibike
minibike's Avatar
The stock goodwrench 350 is a low compression/small cam engine. It should be very dependable, but I remember putting one in my 80 burb, and not being too satisfied with the performance.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 04-22-2003, 07:20 PM   #12
cali_surfer
cali_surfer's Avatar
There's the ever-popular Vortec head swap and cam change that will wake it up. Bolting on a set of Vortec heads with screw-in studs/upgraded valve springs and a small Comp Cams Extreme Energy cam will give you more power, guaranteed.
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 04-22-2003, 09:47 PM   #13
Dads72
As was said before - hook up that cable and get it adjusted correctly.
Spinning the tires looks cool, but it makes you go slow.
What tire pressure are you running?
Put some more in there if you want to make smoke - and lose traction.
Did I mention this before? ---- Hook up that cable!
Wish I had the same problem.
Dads72 is offline   Reply With Quote
Old 04-23-2003, 12:44 AM   #14
Joachim
Carolina Cajun
Talking
Add a bottle of Tabasco to the tank, that should heat it up a bit !!
The Carolina Cajun, almost famous in North Carolina since 1989!
Driving a 68 & Restoring a 66.
Lookin' for Rochester Manual 1bbl & 2bbl carbs!!
Concord, NC & Ponchatoula, LA
Joachim is offline   Reply With Quote
Old 04-23-2003, 01:32 AM   #15
Hooter
My other Love
Hooter's Avatar
its definetly your tv cable, adjust it now or you wont be going anywhere (take it from one who already found out the hard way)
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 04-23-2003, 02:02 AM   #16
Dropt72Shortbed
Dropt72Shortbed's Avatar
i have one in my 72, with stock th350 3.73 posi and edelbrock intake, carb and headers with flowmasters. 28" tires stock
my truck blows my dads 01 pontiac GTP off the line (supercharged v6, 15.0 car) however he does catch up to me after 40-50.
im very happy with my stock engine, takes out my friends 00 silverado with 5.3.
Dropt72Shortbed is offline   Reply With Quote
Old 04-23-2003, 02:26 AM   #17
Project1970
14.1 @ 96MPH
Project1970's Avatar
I'll say it again - HOOK UP THE CABLE!!!
Aside from that...if you want some good power, add Vortec heads, a bigger cam, and headers.
As it is...I'm running 15.7's at 86.6 with a Comp Cams 260H, Performer Vortec, HEI, near-stock exhaust, 700R4, and 3.73's. I want to, at the very least, swap the cam for an XE262H, and the ram's horns for headers and an H-pipe...ideally, I also want to swap the bottom end for a 383 or 406.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-23-2003, 04:50 PM   #18
lotik
i am having problems hooking up that cable. i think i need a cable gas pedal. i had to flip the bracket for the kickdown over so it would miss the gas pedal rod. but the kickdown cable wont reach the spot its suppose to hook up at. i guess i will figure something out.
Old 04-23-2003, 05:59 PM   #19
Jackal2k9
Jackal2k9's Avatar
do you have an exhaust sytem or are you running open headers? it wont make torque and youll never break your tires loose without back pressure on that motor. I have a 383 with ported heads and a 650 holley flat tops et cetera that is JUST BARELY filling 1 3/4 in headers and a 2 1/2' h pipe system. Im thinkin of going back to ram horns... Advanceing your timing significantly (20-30 degrees INITIAL advance!!!) can account for that some but you will still burn up valves otherwise destroy the motor. Get it idling smooth and quiet and put a light on your timing. if your much over 16 degrees initial adavance with that cam you probably dont have enough backpressure.
Jackal2k9 is offline   Reply With Quote
Old 04-23-2003, 09:59 PM   #20
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Lotik, I agree on the TV though, get that hooked, also, when you do it shift it intolow gear
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 04-23-2003, 10:38 PM   #21
crazy longhorn
Fabricate till you "puke"
One more time......do get the tv cable set up properly! those 700r4's are very touchy about that, you will lose the trans fast without the cable(ouch). I think a set of 3.73 gears would be a great "bang for the buck" & help the power a bunch. You can add any upgrades the the eng later....hell its fresh, id run it. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-23-2003, 11:34 PM   #22
tom hand
CCRider
tom hand's Avatar
Well besides the fact you don't have the tv cable hooked up, which "holley dominator intake" do you have? If it is the single plane strip dominator it will really make that motor a dog. Wrong rpm range for the motor... my crate 350 will smoke the tires as long as you hold the pedal down
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-23-2003, 11:35 PM   #23
Ackattack
Ackattack's Avatar
It sounds like you need to get your TV cable hooked up too.
If yoiu don't have enough power, a little nitrous will take care of that (Though I'm not a big fan of NO2)
I'd say a head and cam swap would help out quite a bit.
Ackattack is offline   Reply With Quote
Old 04-24-2003, 12:23 AM   #24
mikep
Used to have a truck
mikep's Avatar
Ok a couple of things.
As had been mentioned before make sure your not running the wrong dominator manifold . If its the strip dominator your'e running the wrong manifold .
Check your gearing. If its 3.07's then c'mon. what do you expect. If you are running decent gearing ala 3.73 to 4.10's with small tires ( under 29 inch tall ) and you still cant break it loose with a reasonably tight stocker motor then you are having other problems.
Cam it! stock cams are beyond worthless for power! make sure to match a cam with the proper intake, gearing, compression and converter though. A edelbrock performer or appropriate clone will work well for the compression you are running.
Hook up the cable ! It won't run right and you'll destroy the transmission if you dont
Ive had a lot of friends and relatives in the motor building biz up to the level of top fuel dragster and that bit about not having enough backpressure in the exhaust system to spin the tires is a bunch of crap-o-la ! Too much pipe will shift your curve up a wee bit but its primarily the cam thats determining the torque curve. You should be OK with up to 1 3/4 inch primaries and all the way up to 3 inch pipes on the way out .
No truck :-(
mikep is offline   Reply With Quote
