Old 04-22-2003, 04:12 PM   #1
78SilveradoSWB
78SilveradoSWB's Avatar
Question Question For Swervin
Where did you mount the air intakes for your ram air system? Did you cut holes into the radiator support?
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 04-22-2003, 04:51 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Mitch,
I already had the hole on the passenger side. The hole on the drivers side had a knock out in the hole I had to remove.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-22-2003, 08:40 PM   #3
78SilveradoSWB
Thanks Mike, I just found another use for a 5" hole saw...
Mitch
454 BB, TH400
Old 04-22-2003, 09:01 PM   #4
swervin ervin
Cool, but make sure the duct will fit a 5" hole first. My Ram Air used 4" duct. Wouldn't be good to cut a 5" hole and it not fit.
Mike
1985 Chevy C-10
Old 04-22-2003, 09:08 PM   #5
78SilveradoSWB
You are right, good thing there is a 4" one in the hole saw kit.
Mitch
454 BB, TH400
Old 04-22-2003, 09:26 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Mitch,
I'm jumping on your post, hope you don't mind.
Mike,
What is the part number for the NGK spark plugs that you use? Do they come pregapped?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-22-2003, 09:57 PM   #7
swervin ervin
Gerardo,
my plugs are BKR5E's. But, these fit my Edelbrock heads, which use washers, not tappered seats like stock heads.
If you need to cross reference NGK plugs, here's a good place to do it.
http://www.clubplug.net/cross.html
Oh, and here is NGK's page. It also has a part finder to use to find the correct plug for a application.
http://www.ngksparkplugs.com/index.asp
Mike
1985 Chevy C-10
Old 04-23-2003, 12:03 AM   #8
gchemist
gchemist's Avatar
Thanks Mike,
Looks like they make a nice oxygen sensor too. I'll be ordering that for my Dakota along with the spark plugs.
Those websites are awsome!!!
Old 04-23-2003, 04:09 AM   #9
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
You should see the looks I get when I ask for my NGK plugs. I tell them the part number and they look out at the truck then shake thier head. I just laugh and tell them it's the aluminum heads on the engine
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 04-23-2003, 01:19 PM   #10
PHOENIX
I dont have a dual snorkle air intake yet, but I punched out the hole when I had the grille out. I just hit it with a hammer from the grille side. It just fell right out. If yours is not the same, then a hole saw should work, just be careful about the placement of the hole. If you do have the factory block off plate there, then you could use the plastic GM peices and cut the air block plate off and pop them in and out, as shown here (passenger side shown):
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
