90-91 Cluster Housing Question
Did they make 90-91 gauge cluster with a clock or anything else in the bottom left space? I have not been able to find one yet. If so, I will post an add in the WTB section. Thanks for any help, Chuck
Re: 90-91 Cluster Housing Question
I forgot to mention its for a 1 ton squarebody
Getting Old; Going Broke
They did not put a clock in the 90/91's because it had a clock in the factory radio.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Still plays with trucks
With the factory tach cluster a fuel gauge went there.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
This is my 91 burb cluster. As you can see It has a clock. But I had to modify the housing to get it in. Had to cut out some of the inner stuff and epoxy a stand mount from another old housing and cut a hole in the rear for the harness to come thru. Not impossible but a little bit of a task. I wanted to keep my clock when I did my ls swap.
Thanks for the info.
Homemade87-- You have the setup that I plan to do. Still searching for the fuel/tach gauge. I know that there is a company out there that sells them, but Im going to try to find one first. |
