Old 12-17-2011, 12:51 AM   #1
Jemo
Any luck routing dome light wire?
The original wire was on the truck but brittle and naturally broke when I tried to gently pull on it. Any ideas on how to route a new set of wires up there?!
Jeff
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 12-17-2011, 01:00 AM   #2
mr48chev
mr48chev's Avatar
Re: Any luck routing dome light wire?
You might try using a piece of stiff single strand copper wire to shove though in one direction or the other and use it to pull the wire (s) for the light through. Pretty much as an electrician would use a fish tape to pull wires through conduit. Maybe even a piece of welding rod or a wire coat hanger straightened out.
Old 12-17-2011, 01:14 AM   #3
solidaxel
solidaxel's Avatar
Here is what I use............. a old broken inner speedometer cable, start at the top of the A piller and just let it slide down the inside of the post and pick it up just under the bottom corner of the dash
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-17-2011, 07:28 AM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
on of the guys on the forum used air compressor to blow a string line up then pulled a new wire.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-17-2011, 09:04 AM   #5
Russell Ashley
Russell Ashley's Avatar
I couldn't get a new wire in so I ran it out through the firewall and down the firewall with the rest of the tailight and gas guage wires. Then I ran it with the gas guage wire up through the rubber grommet and then fished it up to the light.
Russell Ashley is offline   Reply With Quote
Old 12-17-2011, 06:54 PM   #6
OKGMC4
OKGMC4's Avatar
Oh! Good call!
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 12-17-2011, 07:05 PM   #7
renegade6
I used a piece of utility wire from the top down thru the front pillar to pull the wire up.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 01-08-2012, 02:44 PM   #8
_Ogre
_Ogre's Avatar
i tried a piece of wire from the top and from the bottom for an hour with no luck.
i found some plastic banding (for strapping boxes together) and fished it from the top in 3 seconds.
shop air compressor timer
Old 01-08-2012, 03:07 PM   #9
Daze57
Daze57's Avatar
i lucked out and was able to use the old original wire - tied a new one on and ''gently '' pulled it all the way thru.- took a li''l time but i got it .
Daze57 is offline   Reply With Quote
Old 01-08-2012, 07:07 PM   #10
booger1949
i also couldnt get threw the post in my 49, so i took a piece of rod down it an it felt soft so i kept jabbin at it an it finaly fell out an its was a bunch of junk that a rat had put in there i guess to live in, no tellin how many years that had been in there
booger1949 is offline   Reply With Quote
Old 01-08-2012, 09:02 PM   #11
Kid
Kid's Avatar
.035" tig rod fished thru windshield postworked for me
Kid is offline   Reply With Quote
Old 01-08-2012, 10:58 PM   #12
JumboAMONGus
JumboAMONGus's Avatar
i worked on mine for three days and just said screw it and left it ,,lol i still cant get it threw the pillar under the dash and the old one i tied new one to broke in the middle
JumboAMONGus is offline   Reply With Quote
Old 01-09-2012, 07:55 PM   #13
starterman99
starterman99's Avatar
on my 57 I used heavy string and put a small fishing weight on end to drop from hole where visor mounts.then a length of mechanics tie wire to fish it up to headliner opening.did this on pass side for power antenna wires to behind pass door.
starterman99 is offline   Reply With Quote
Old 01-09-2012, 09:46 PM   #14
booger1949
now u have everybody wonderin what is stuck in there, jab it dude jab it
