Old 12-17-2011, 05:47 PM   #1
ryans69chevy
Building an Instrument cluster!
Want to build an instrument cluster for my 69. Want it to look just like the factory or close to it anyway. Adding a clock and maybe thinking of getting my background to be white and also interested in an 8k tach that looks original.
Has anyone used the 8k tach? Any thoughts on it? Is it accurate? Do you need to make a lot of modifications to make it work? My truck currently only has fuel gauge, speedometer, and generator light. So it's just the basic three hole bezel. My reason for wanting an 8k tach is I'm putting a BBC in the truck so I don't want to peg the 5k tach out all the time.
Is it easier to run a printed circuit board or could I just leave that off and wire these gauges in themselves? Just in case I decide to move the clock in a different place than what everybody else puts them if that's even possible?
How much would it cost to build a cluster like this? I know you can buy the cluster with an 8k tach from Classic Industries and places like this for close to $700. Would it just be better to go this route? I think it would be fun to build it myself though and maybe I'll save some money in the long run.
Thanks,
Ryan
ryans69chevy is offline   Reply With Quote
Old 12-17-2011, 06:36 PM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: Building an Instrument cluster!
look at this http://www.ebay.com/itm/ws/eBayISAPI...B:FSEL:US:1123
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 12-17-2011, 08:36 PM   #3
coops714x4
coops714x4's Avatar
that's a pretty good price for that feebay cluster. first of all if your running a stock bbc the 5k tach is all you will need, 4k on a stock bbc is pretty tight, second if your engine is a hot rod, you should want more precise guages. third if all you have is the warning lights I would think it would be a nightmare to wire each "factory" guage (but I hate wiring) if it were me I would buy cluster mentioned above and change the wiring harness and be done with it.
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 12-18-2011, 03:11 AM   #4
Classic Bowties
Always on the hunt...
Originally Posted by ryans69chevy View Post
Has anyone used the 8k tach? Any thoughts on it? Is it accurate? Do you need to make a lot of modifications to make it work? Thanks, Ryan
This is the type that will look close to stock, and this 8K is available in a hands on convert it yourself kit form or in complete already built tach cluster form. The one pictured below was a 8k kit installed/combined with parts from an original non-tach cluster. I have built quite a few of these since the kit became available and have not heard any neg. fb about them as of yet from any of the purchasers. I do remember checking and verifing the first couple put together up against my sunpro digital and the needle sweep was spot on to 4k or so, definitely more accurate than some of the 40 year old originals I have had. Mel
Classic Bowties is offline   Reply With Quote
Old 12-18-2011, 03:51 AM   #5
black_sheep454
Im posting in this thread so I can find it later when I do my engine swap. That's a nice original looking 8k tach.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 12-18-2011, 04:40 PM   #6
ryans69chevy
Mel, that's exactly what I'm looking at building! Only I will prob go with the black bezel and of course add the clock in that blank spot. Are they pretty difficult to build? Don't really seem that tough, just time consuming. Does a person save a lot of money going this route or buying a complete cluster already put together? As I told you before I don't have any of the "dummy" gauges and I will prob have to buy a new speedo since mine was acting up before I parked the truck. Are you buying the circuit board or hardwiring them in? I'm up in the air about that...I think I could clean it up a lil bit if I hard wired them all in... I'm lovin the look of that 8k tach tho!
Old 12-18-2011, 06:14 PM   #7
gotchamel
I just put together a 7 hole cluster with all VDO vision series electric gauges.120 mph speedo and 8000 tach.I wired it all using factory wiring for the most part, except for oil/water/tach sending wires.The clock will be a tough one,atleast if you want it to fit the center hole.A 3 3/8" gauge fits perfectly but I could not locate a clock that size.I did contact a speedo/gauge shop that will build one to match for around 400.00.I wired it quick disconnect with a 12 pin connector.I do realize that pics would help,I will take some when I drop the cluster.
gotchamel is offline   Reply With Quote
Old 12-18-2011, 06:38 PM   #8
ryans69chevy
I have a quartz clock already. It fits in the blank hole directly to the left of the oil pressure gauge. Yeah, you should take some pics of the wiring!
Old 12-18-2011, 06:46 PM   #9
gotchamel
I have approx 500.00 in my cluster including a new 7 hole bezel,all gauges,senders,lights and wiring.I like it better than the stock clusters but it still has a stock look.
Old 12-18-2011, 07:06 PM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
This is in my Jimmy. The truck has a supercharged BB. Member Eric Ricks made it for me. I think it looks like it belongs in the truck, and it is accurate.
Tom Vogel is offline   Reply With Quote
Old 12-18-2011, 08:14 PM   #11
flashed
Dang ,that is nice .
flashed is offline   Reply With Quote
Old 12-18-2011, 09:27 PM   #12
Hart_Rod
Hart_Rod's Avatar
Sweet!!! Why two fuel gauges?
Hart_Rod is offline   Reply With Quote
Old 12-18-2011, 09:58 PM   #13
DaHos
DaHos's Avatar
SUPERCHARGED = Fuel Pressure Gauge, Fuel Level Gauge
DaHos is offline   Reply With Quote
Old 12-18-2011, 10:12 PM   #14
Hart_Rod
Hart_Rod's Avatar
Good catch!
Old 12-18-2011, 11:41 PM   #15
a2tripp
a2tripp's Avatar
those valve covers in your avatar are schnazztastic!
89 GMC V3500
Alaska members check in
a2tripp is offline   Reply With Quote
Old 12-19-2011, 07:57 AM   #16
I use the 8k GM tach that Classic Bowties showed on hot trucks and it's just the ticket! I have a totally custom dash in mind for a vintage hot rod theme,but if I told you before I do it I'd have to kill you
Old 12-19-2011, 10:13 PM   #17
ryans69chevy
haha that's alright! I think I might do that 8k tach then! The only other question I have is if I should build one or just buy one totally done...
Old 12-24-2011, 11:03 AM   #18
71BB_LWB
Thread Killer!
71BB_LWB's Avatar
You could go custom bezel also.
I had a plate cut on a water jet and used a stock bezel behind it.
Check my build thread for more pics.
71 Cheyenne SWB LS1 and auto.
http://67-72chevytrucks.com/vboard/s...d.php?t=256470
_____________________________________
If it's worth doing, it's worth doing twice...
Don't Mistake Honesty for Negativity...
71BB_LWB is offline   Reply With Quote
Old 12-24-2011, 11:12 AM   #19
dmwphoto
dmwphoto's Avatar
some good looking stuff guys. I will throw in some pics of the one I built for mine.
dmwphoto is offline   Reply With Quote
Old 12-24-2011, 11:56 AM   #20
big_al_71
big_al_71's Avatar
Here is a picture of the one in my truck....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
