1970 Chevy C-10 5.7L Gas 400 Trans.
Had the breaks inspected, bearings and alignment done. All is well. Gping 30-45 the truck runs well. Going about 65-70 it seems sluggish. I am not sure what could be causing it. New spark plugs and tune up done. Just seems as though it is trying to pull back when I am going that fast. Any ideas? R |
"brand new second-hand"
Re: Sluggish at High Speed
check the hose coming off "ported" manifold vacuum( on the carb) to the distributor for leaks and cracks. Also, check to see your vacuum advance is working on your distributor. If those are good, look for anymore vacuum leaks and then check your fuel filter,fuel pressure and float level on your carb.
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
I built it
did the truck recently start being sluggish? my truck is like a garage door on the freeway at all times haha
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
Old Skool Club
![]() Join Date: Jun 2001
Aerodynamics are not the strong suit on these trucks. Add in a 3:73 rear gear and you are getting close to the limit of what may be doable. Still, it should run 70MPH without much effort.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
It started about 2 months ago. Before that it used to run beautifully
Posted via Mobile Device |
Mine was doing that and it turned out to be trash in the gas and had the filter clogged.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
Cam might be going flat. Pop off the valve covers and check the rockers.
I highly doubt it's the cam. It was installed brand new last year. It's a high performance can too.
![]() Posted via Mobile Device |
New springs too!!
