Old 12-17-2011, 07:28 PM   #1
Holt
Need help finding Radiator
i have a 67 c10 with a 350 bored .060, having trouble finding a 4 row core using 67-72 as my vehicle yr. when searching. is there another yr that 4 rows are more common that will fit. or is there another way to go about it? should mention that i am wanting to find a radiator that also cools transmission fluid
Holt is offline   Reply With Quote
Old 12-17-2011, 07:44 PM   #2
black_sheep454
Re: Need help finding Radiator
Not sure about the trans cooler but try looking at one for like a 71-72 3/4 ton big block truck.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 12-17-2011, 10:38 PM   #3
Bert W
Bert W's Avatar
I seem to remember a recent junkyard crossover post that contained some info about a radiator from a later model year truck that fit our 67-72 trucks. It's been within the last two weeks.
Here it is: http://67-72chevytrucks.com/vboard/s...d.php?t=248607
I don't know if they are 4 row or not, near the botom of the list.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 12-17-2011, 10:39 PM   #4
repeeler
repeeler's Avatar
Got my 4 row at O'Reilly for about $220. Part # : 433369
Ray
1971 Cheyenne LWB
1965 C-10 Short Fleetside 350/350
2010 Harley Davidson FLHTK
repeeler is offline   Reply With Quote
Old 12-17-2011, 10:55 PM   #5
hugger6933
I put a heavy duty cooling radiator from a like 93 chevroket truck in my 70. The rad hoses were a little different on the top hose but I think I used the stock hose on the bottom. That rad will provide ample cooling for your needs. I did however discover that a reduction bushing will be needed for the bottom. I had a leak on mine there after installation but just pulled the bottom hose off cause the cold weather is here and I have plans to take that truck down to start a quick rebuild and clean up the motor add a 5 speed overdrive and cam intake 4 bbl HEI and headersw/dual pipes. And while I have the motor out I figured why not freshen the truck up with new bushings and the core support was rusty so I'll fix that and the fender cup and the bent fender and and and..... Is'nt how the snowball starts. A 30 dollar tune-up turns into a frame off restoration. By the way while I have the front off, I might as well put the cab on the rotissere, Right ? I mean it is setting out there with nothing on it.....
hugger6933 is offline   Reply With Quote
Old 12-18-2011, 12:00 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Pretty common radiator. A 4-core radiator for these trucks are available from a lot of sources. If your truck had an auto tranny... then the radiator had the bungs for the tranny cooling lines as well.
You'll spend around $220 to $400 depending on where you find them at.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-18-2011, 01:03 AM   #7
allchevy58
allchevy58's Avatar
Got the same one repeeler got O'Reilly #433369 $175.00, identical to the original radiator.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-18-2011, 02:55 AM   #8
capev86
in 1990, my dad tried to use the new 4 core from his 72 burb c10 in his newly acquired 84 c10 and it didn't fit. my 72 burb c20 has a 307, 3 on the tree and no a/c but i wanted a 4 core for towing (and for the overkill factor). i got a new 4 core from Jim Carter 2 years ago for like $200. soon afterwards they started phasing out their 67-72 line of parts (too much competition) so i'm not sure if they have any more to sell or not. mine does have the provision for trans cooling (just threaded plugs into the holes to keep crap out). i got extra lucky - my dad still had the 7 blade from his burb (w/ 350/350 and factory front a/c). when he sold the truck in 91 it had another fan on it and so that factory correct "performance piece" was collecting dust in the attic....now it's on my truck!
capev86 is offline   Reply With Quote
Old 12-18-2011, 03:10 AM   #9
Blue72slab
If you really want to cool the trans fluid for towing, etc. you should run an external cooler IMO.
Larry
1972 Chevy C20 Custom Camper
1968 Chevy Camaro RS
1980 GMC K5 Sierra Classic
Blue72slab is offline   Reply With Quote
Old 12-18-2011, 03:38 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you can't find a 4 row rad with a tranny cooler, then you need to shop somewhere else. It was a common piece in these trucks.
Old 12-18-2011, 04:03 AM   #11
capev86
yeah...that too. i don't have to worry about cooling an auto trans except in my current daily driver. the 72 burb and 87 ram 50 both have manual trans and my dodge k wagon will be getting a built 5spd to go with the 200hp/250tq 2.5 turbo intercooled engine it's getting.
get the biggest darn cooler you can and plumb it so the hot fluid goes to the aux cooler first and then to the radiator. that will get rid of a ton of heat and the freshly cooled fluid will help draw heat out of the radiator.
another item to consider is some synthetic atf as it lasts longer, takes the heat better and provided better lubrication. automatics see a lot of abuse and can use all the help they can get. and don't run that orange dex-cool crap that GM puts in it's cars. not compatible with regular green fluid (they do make green stuff that will mix with either) and it will eat engine seals i've heard.
Old 12-18-2011, 06:10 PM   #12
Holt
thnx guys i don't know why i was having so much trouble with oreilly's website, radiator popped right up using that part #
thanks again!
Old 12-18-2011, 06:37 PM   #13
cdowns
cdowns's Avatar
you will need to get new 4 core specific mounts if you did not have a 4core to startoff with
Old 12-18-2011, 09:28 PM   #14
GASoline71
GASoline71's Avatar
The "cat" makes a good point about the new mounts. Especially the upper brackets are longer.
Gary
Old 01-18-2012, 07:42 PM   #15
Derek71784
I'm looking into replacing mine as well. The route that you guys have posted with the O'reilly's radiator looks good to me, I just have to find the mounts and I'll order it all today....now.... where do you go about finding some mounts?
1969 C/10 SWB- Built 350/TH400/12-Bolt (Under Construction)
-Amateurs practice till they get it right, professionals practice till they get it wrong-
Derek71784 is offline   Reply With Quote
Old 01-18-2012, 09:09 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Any of the BB vendors will carry the mounts.You'll need a drill and hacksaw or die grinder to mod the core support slightly.Not abig deal and only takes a few minutes.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
