12-17-2011, 08:48 PM | #1 |
Mark v heads on Mark IV block?
Am building a 496 and was going to use a set of 049 GM oval port heads. I came across a set of 088 rect. ports off a 502 mercruiser for a reasonable price. I have heard you can run the newer heads on an older block but not the other way around and I have heard you can use older heads on the newer block but not the other way around. Both versions I have heard you have to use a special heads gasket. Has anyone done this? If ya have do you have the part number for head gaskets the later model heads to mark IV block?
12-19-2011, 02:06 AM | #2 |
mini truck racer
Re: Mark v heads on Mark IV block?
I have run the older style heads on the newer style block . This was a 468 . It required a special head gasket due to the water jacket/coolent ports . I will see if i can find the info tommorow .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-19-2011, 08:25 AM | #3 |
the 502 heads are non adj valvetrain.. you are going to need to change all the valve gear to get adj valvetrain
12-19-2011, 08:46 AM | #4 |
I would just have to buy studs and guiide plates they are already machined. I also found an article in Chevy High Performance where they used the 088 heads on a Mark IV 505 build that's very similar to the build I am doing and they listed the head gasket number I need. Thanks for the infomations guys.
Posted via Mobile Device |
12-19-2011, 05:57 PM | #5 |
Those are the heads that i'm running... They flow pretty dang good for an iron head!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
12-23-2011, 03:57 AM | #6 |
Yeah they are actually a little on the big side for what I'm doing but for the price I couldn't pass them up. I am doing a 10.2 to 1 496 with a mild street solid roller. Would like 550-600 horse and close to that intorque. Truck is rather light... about 2800Lbs with the small block in it. So if I get close to those numbers I can try to run the 6.5 index at HMP here in Houston.
01-07-2012, 07:33 AM | #7 |
Well plans changed. No more local index racing. Sold my BBC stuff, except the heads and doing a little SBC for the truck and will do more street driving and a little bracket racing. I am thinking should I use this virgin 509 400 block and do a little 406 with a decent set of heads and hope I dont go to far for the block or use one of my 010 350 blocks and do a 383 or 396 and just not worry so much about it? Seeing as I am also trying to restore my boys camaro at the same time I can't budget a block in so its what I have or nothing.
01-07-2012, 10:15 PM | #8 |
mini truck racer
What body is this going in and what weight ?
01-08-2012, 01:32 AM | #9 |
Truck weighed a little over 3300 with me in it with the aluminum headed SBC in it. I have built a few 400's and never hurt one but I was going to do 6" rod dart 230 heads with 10.5 to 1 compression. Do a street solid roller. That should be close to if not 500hp so if I spray it at all I am worried I would be getting close to the limits of the GM block even if I Hardbloked it and used a girdle.
01-17-2012, 05:19 PM | #10 |
If you need the part number for the head gaskets your best option is to goto your local parts house ( I went to Oreilly). Have them break out the felpro catalog there is a whole section in the catalog for BBC head gasket interchange. Different bores...different thickness.... really useful for me. I'm putting together a .70 over 454 right now with 088 heads and the gaskets They said to use were like a hundred bucks a pair!! Hopefully they work for that cost!
70 longbed 496/th400/Ford 9" |
