![]() Join Date: Feb 2011
Temp sending unit
I have a 72 350. It has temp sending unit on both sides. I know one is for tcs and one for temp gauge. Driver side has one little post and pass side has one blade. Question is which one is which, I want to plug tcs side. Thanks
![]() Join Date: Apr 2011
Re: Temp sending unit
What is tcs becouse my 72 BB 402 is the same way.
Sierra Grande Club
You want the one on the driver's side (single post).
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Sierra Grande Club
TCS= Transmission Controlled Spark IIRC.
Chemist under the hood...
I think what he's saying that one is for the temperature switch (for TEMP light) and the other is the temperature sender for the temp gauge.
I think the probe with the post/terminal is for the sender (to the gauge) and the probe with the blade is for the switch (dash light). LMC truck has a good picture in their 67-72 catalog (pg 155). http://www.lmctruck.com/icatalog/cb/full.aspx?Page=155
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Sierra Grande Club
^ both with and w/o gages go on the drivers side.
Sierra Grande Club
Here's a wiring diagram but it don't show the TCS system.
http://www.boomspeed.com/bofh1968/ch...ng_diagram.pdf
![]() Join Date: Feb 2007
Different years have different options. The 1972 has both a temperature gauge and a temperature warning light.
The drivers side is the single post for the Temperature gauge. The passenger side is the single blade for the Temperature warning light. Do not buy these sending units at a local parts store. They will be wrong. Buy them from someone that specializes in these trucks like: http://www.classicheartbeat.com/electrical_p-4.htm Here is a link for information on the TCS. (Transmission Controlled Spark). I don't believe that's what you are asking about. You'll have to click it again to make the diagram enlarge. http://img232.imageshack.us/img232/1226/tcs14bb.jpg Below are pictures showing the Temperature sending units, the gauge and the light. The Temperature warning light is on the far right passenger side. I use that to remember that the temperature sending unit for the light (single blade) goes on the same side. You can't tell from the picture, but the light reads TEMP. Last edited by FLcustom10; 12-18-2011 at 12:58 PM. |
#9 | |
Sierra Grande Club
What size wires did you use?
- 1967 Chevrolet C/10 SWB fleetside (New Project). ![]() - 1969 Chevrolet C/10 SWB fleetside (SOLD) ![]() - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Agreed that you do not want to buy these from a parts store. Get them from someone that knows these trucks. I bought an aftermarket ignition switch and it didn't work properly. It is supposed to ground during cranking so that the idiot lights come on when you are starting the truck. Mine wouldn't light. I finally traced it back to the aftermarket switch. Once I replaced it with an OEM AC Delco switch I had no problem.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
