12-18-2011, 12:00 PM | #1 |
Help with Messy Spark Plug wiring
I have a new set of Plug wire for my HEI is but they are really messy. Any recomendation on best way to route would be appreciated. Engine, 307
has old Hooker Long Tubes and that is part of the problem. |
12-18-2011, 12:02 PM | #2 |
Sierra Grande Club
Re: Help with Messy Spark Plug wiring
Going underneath like factory is best IMO.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-18-2011, 12:06 PM | #3 |
Sierra Grande Club
Here's the diagram.
12-18-2011, 03:04 PM | #4 |
I'm going under with my Accel wires.
Brad handshoe |
12-18-2011, 03:57 PM | #6 |
Any thoughts on the brand/model number for under exhaust loom kits? Thanks
Posted via Mobile Device |
12-18-2011, 04:48 PM | #7 |
real nice the way the cheap rubber gasline runs it is in great position to come to rest on the exhaust manifold and burn your truck to the ground
12-18-2011, 05:05 PM | #8 |
This is how I do mine
"Negative people always seem to have a problem for every solution" |
12-19-2011, 04:27 PM | #9 |
So,, what else you got???
We went with the Made 4 You holders on our big block and were really happy.
12-19-2011, 05:06 PM | #10 | |
12-19-2011, 05:46 PM | #11 |
!!!!! Only way to make that more deadly would be to use one of those inline filters with the glass canister.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
12-19-2011, 10:42 PM | #12 |
looms
Fuzzy |
12-20-2011, 12:35 AM | #13 |
12-20-2011, 01:03 AM | #14 |
Telling him to fix that is advice, FWIW. When it warms up under the hood that stuff is gonna get hot and limber up some.
12-20-2011, 01:17 AM | #15 |
Gotta agree with webfoot, i would want someone to tell me if they saw something wrong....were here to help
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-20-2011, 02:13 AM | #16 | |
At least reroute your fuel line over your ground cable, this way it has something to keep it from hitting the manifold. Looks like you already had something melt on the drivers side, so PLEASE do us all a favor and get this fixed, last thing we want to hear about is someone getting hurt or see another one of these trucks get burnt to the ground. My truck caught on fire for this exact same reason, previous owner tried to hide the fact when I bought it, but it was pretty obvious. He came clean after we worked out a price. here is the motor the day i bought it, you can see where it caught fire all rubber items where melted gone. & paint was burnt off the hood On the cables, if you don't want to make your own, buy a set from the auto-parts store for a 70's corvette, they are long and can be routed under or around without any issues this image shows how long the vette wires are. Rear cables are routed under, front are routed around. Not the best options, but it works for off the shelf wires. Good Luck! -=Scott=- Last edited by AustinScott; 12-20-2011 at 02:20 AM. |
12-20-2011, 06:01 AM | #17 | |
i wont and cannot keep my mouth shut about very serious safety hazards like this
12-20-2011, 08:14 AM | #18 |
I've had bad luck running them under the way GM did. I go over and nothing fancy,but easy and cheap. Haven't burnt a wire in seven years since I put the motor in:
12-20-2011, 08:17 AM | #19 |
I dun gradjiated collij!!!
Cdowns - I too used to roll my eyes and get irritated on your constant harping about the dangers of rubber fuel lines.... It drove me bonkers as it seemed like every other thread was another stern warning from you on the use and routing of rubber line....
Then I started catching myself slowly removing and / or rerouting my rubber lines away from heat sources or moving objects with all those warnings creeping out of my fuzzy memory. I also started looking at some of the burned out heaps in the local yards...Some of the older ones had some long spans of air between the stubs of metal line protruding from the pump and carb.... makes you wonder how much rubber used to fill that void. Anyway my point is this: You wouldn't consistently warn folks if you didn't care, and that is one of the things that make this board great....keep it up. Thanks again....
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
12-20-2011, 10:18 AM | #20 |
CD Downs. Thanks for the comments on the fuel line. I will reroute and am going to get a steel braided fuel line. This truck is not being driven at this point. Just worked on.
Thanks all for the wiring. Got some ideas now. Posted via Mobile Device |
12-20-2011, 10:29 AM | #21 |
Not gonna make it in the SEMA show, but I've not burned a wire yet! When your all done with yours, post a pic.
12-20-2011, 11:52 AM | #22 | |
"brand new second-hand"
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
12-20-2011, 12:10 PM | #23 |
Frequent Flyer
I like these for more original (or less chrome) applications...
And these for custom with chrome... |
12-20-2011, 12:15 PM | #24 | |
(Don't) ask me how I know! |
12-20-2011, 01:10 PM | #25 |
well i'm very glad that some are listening to my warnings// a great christmas present for me
now as far as the spark plug wires// lots of great pictures to go by /// summit jegs and speedway motors all have many options// i love the qualitry and look of the "made for you" ones if you are on a tight budget? a cheap good way that i like // i prefer running the wires to the bacck of the head and up along the valve covers and drop them down i hate the stock milelong ones most heads on the backside have unused bolt holes// easy to take a piece of scrap steel or aluminium drill a couple of holes then cut to size and fit paint or polish and you have an anchor place for zip ties to hold wires in place// same thing with bolts holding valve covers in place a little piece of metal with holes discreet ziip ties and you can have a nice CHEAP tidy job in a few hours work for next to nothing
