Old 12-18-2011, 12:07 PM   #1
cwilkie
Chance
cwilkie's Avatar
1972 3/4 ton 4x4 Big Block Mounts (HELP!)
Hello all. I have a 1972 3/4 ton 4x4 with a tired and leaky 350sb in it. I have a rebuilt 472bb that is going to take its place. Here are my questions.
1. How do I mount it to the frame?
2. How far ahead do I need to move the engine for HEI?
3. Will the mounts and clam shells out of a 73 and up 4x4 with a big block work?
Any help is appreciated since I am lost on what to do at the moment.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 12-18-2011, 12:37 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: 1972 3/4 ton 4x4 Big Block Mounts (HELP!)
Chance,
Use the OEM small block engine mount setup. move everything approx 2 1/2 inches forward in order for the valve covers and HEI to clear the firewall. (you can leave it all in the stock location if you do not mind clearancing Hammering) the firewall for the HEI and valve covers).
The down side of moving it all forward means dealing with different drive shaft lengths, shift linkage etc,
Livrat is offline   Reply With Quote
Old 12-18-2011, 08:45 PM   #3
cwilkie
Chance
cwilkie's Avatar
I prefer moving everything forward. I prefer to not use the small block mounts and stands. Will the two wheel drive towers from a 1972 or the 67-71 work? Or could I just use some clam shells and mounts from a 73 and up 4x4 that had a big block in it? Thanks.
BB 396 w/TH400
BB 496 w/TH400
Old 12-18-2011, 09:36 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
The 2wd towers will not work. A 4x4 uses a "cradle" from frame rail to frame rail. You will be fine using the small block setup. That is what most people do. I think there is a company the makes a conversion, but i don't know anything about it.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-18-2011, 10:16 PM   #5
superchevy
Got big-block?
superchevy's Avatar
Use a DIY crossmember/engine mount combo for 4x4's. That's what I used on my '72 K25 big block. See my build thread in my sig for pics.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
