12-18-2011, 05:55 PM | #1 |
Front turn signal socket - where to buy
Where can I buy OEM quality replacement front turn signal / parking light sockets? I've tried the cheap plastic ones from AZ and AA; they fit poorly and tend to fall out. I tried a search and didn't find the answer.
12-18-2011, 08:18 PM | #2 |
Re: Front turn signal socket - where to buy
I got mine from ORileys. They came with several inches of the same color coded wire, the fit good and did not fall out. I dont have the number with me, but they were around $6.00 apice. Hope this helps.
12-19-2011, 02:03 AM | #3 |
Scrapper 1
you can Give M&H wire harness a call they make the repop harness for all the car shops they use new factory plug endings
12-19-2011, 09:56 PM | #4 | |
I'll try M&H. |
12-20-2011, 08:33 AM | #5 |
Do you have a wiring issue or a plug issue? On my '83 I have had to replace the ground wire in both of my front turn lamps. I just pulled the one wire out of the new plug and spliced it in and kept the original plug and original hot wires untouched. Still fits nice and the light works again.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
12-21-2011, 06:42 PM | #6 |
I finally found my reciept. From O'Reillys ...CTI 85814 is the number. Sold for $4.29 EA. Hope this helps.
