Removing Leafs To Level?
Searched but didn't have much luck.
I got new rims on last night and with the smaller tires the stance of the truck looks odd because the front is lower than the rear. I'd like to not add 3/4 ton springs on the front because the tires would look smaller so I'm hoping I can remove some of the leafs in the back. How many would I need to remove to make the rear even with stock 1/2 front springs? If it is possible to remove them to make it level, how can I take apart the leafs? Thanks! Michael
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Re: Removing Leafs To Level?
before you start, measure it.. how much do you want to drop the rear end
Was looking at these
(http://www.ebay.com/itm/73-87-CHEVY-...14954250715195) Would installing these level the rear without having to modify the leafs? I think the rear is 2" higher. Just stock height. Would have to measure when I can get up to the shop again.
if you get the Shackles measure your leaf Spring Width i got some from Azone and where the shackles hook up to the hangers was too wide
My 86swb was lowered by taking out a leaf in the rear and cutting 1.25 coils out of the front. It gives a slight rake. 2 leafs removed levels the truck
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
GM Addicted
order a summit racing drop shackle. Thats what i ordered. There repackaged ground force shackles.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
GoatLube Experss
![]() Join Date: Oct 2009
I have the AutoZone shackle's on mine, they fit fine with no issue's.
shackle's will be your best bet but keep in mind you will have to notch the brace that goes across the bed right above the shackle for clearence. if you need to lower it after the shackles then consider front hanger's or remove'n a leaf.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
1 pallet of cement or sand and it will ride level.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
I ordered a set of 2" drop shackles last night. I have the G50 "heavy duty rear suspension" option on my truck so I have the 56" leaf springs so the shackle sits behind the bed cross brace. Shackles are much easier for me now since I realized I didn't have to cut anything. Thanks for the replies though!
