Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-18-2011, 10:57 PM   #1
Bardahl
Sound Systems, Stereo`s
How are guys fitting and what are you doing for sound, i want to leave my Gold radio delete in my 68 Anni. edition the dash is almost perfect and want to leave it clean, Ipods?, how are you getting sound from Ipods to speakers?, I thought about under dash but dont want clutter any other ideas? anyone??
Bardahl is offline   Reply With Quote
Old 12-18-2011, 11:14 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Sound Systems, Stereo`s
I'm running a CD head unit and 6 disc changer in the center console. I wish I had an ipod connection rather than the cd changer, but I bought it before I got an ipod.
Someone on here was making a box to mount a head unit in the glove box. If you get a head unit with a remote and and RF relay, you won't have to reach across and everything can be hidden.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-19-2011, 01:13 PM   #3
SamMargritz00
SamMargritz00's Avatar
probly not what your looking for but i converted my dash to fit a double din stereo. i wired in a relay so you don't have to be in park do watch movies. but i have a cable that goes into the back of my headunit so you can control your ipod on the head unit or with the ipod itself and ran the cable from behind the dash and under the carpet to the center console. in my uncles jeep he has his head unit built into his center console. i thought it was a good idea, kept the dash clean and still has good sound.
SamMargritz00 is offline   Reply With Quote
Old 12-19-2011, 02:14 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
You can run an ipod without a head unit, but it would be compressed sound. Nothing horrible if you're just looking for a simple music set up. You'd need an amplifier to run the speakers and you'd hook that up as normal, but the remote wire would be wired to a keyed switch rather than the head unit. Then, you just need a wire that connects from the headphone jack on the ipod to the rca jacks on the amp's input. Put the amp under the driver seat and route the headphone jack wire to a clean spot and you're done!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-19-2011, 03:14 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
TubbedII is right, I have also seen people use things like this things like this in conjunction with a small amp. It could be mounted below the dash or in a console etc to give you a little better sound quality (At least I've been told, but I'm not sure exactly why) and an easily adjustable volume knob as opposed to having to fumble with the ipod volume. The RCA outputs would go directly to you amp.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-19-2011, 04:48 PM   #6
Bardahl
Excellent, thanks everyone that has responded, getting some real good ideas from these, it should be no real problem to get a clean and crisp sound to some speakers from the like s of an iPod ! anyone else???
Old 12-19-2011, 05:25 PM   #7
SamMargritz00
thats a good idea! i never knew they had such a thing. looks like itd be a breeze to put it.
Old 12-19-2011, 05:32 PM   #8
SamMargritz00
Amazon.com: Belkin Audio Y Cable Splitter 1-Mini... Amazon.com: Belkin Audio Y Cable Splitter 1-Mini... idk if that would work or not, have that go to your amp. thats what we got for listening to the ipod on the shop stereo.
Old 12-19-2011, 08:52 PM   #9
Critter
Future TOTM Winner
Critter's Avatar
Personally, I have used things like this to connect to an RCA input. It has the ability to power the ipod so that it stays charged. The only thing to be careful of is make sure you get the proper voltage for your ipod. Older Ipods take a straight 12V input, newer ones (from the last couple years or so) need a 5v input so the cable would have a built in resistor to accommodate.
Old 12-20-2011, 11:29 AM   #10
pumpkin
pumpkin's Avatar
I plugged my I pod into an equalizer the was connected to a sub amp, and a four chanel amp. The sound was as good as the components I used.
pumpkin is offline   Reply With Quote
Old 12-20-2011, 06:56 PM   #11
Firebirdjones
I simply bought a modern CD head unit that has a USB port for the Ipod. I can plug it in and have 600+ songs and work it with a remote control. Easy and simple, and it sounds great to me.
If you want to get creative you can hide it all. I chose not to since it's a daily driver. I use the glove box and console to store too many things
Firebirdjones is offline   Reply With Quote
Old 12-29-2011, 01:03 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
just put a new pioneer unit in the 78 Jimmy(below)
stock was 1 speaker AM
i still use the other ipod charger unit to talk hands free(or charge the phone)
i can even use the (radio)usb plug to charge the phone and the holder(not part of the pioneer radio)
which powers the hands free part threw the lighter plug not the usb
i bought the pioneer blue tooth radio ,
but didn't like it i returned it and got the same unit i bought in the first place
the blue tooth unit went onsale before i installed it less then 2 bucks more
but i got a sale price on mine anyway under 100 instead of almost two
pioneer has software built in for ipod music (gives better sound) others might too
the blue tooth didn't play the music or charge the phone without plugging it in usb
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-29-2011, 01:14 PM   #13
Firebirdjones
That is the exact same head unit I purchased for mine. Works great. Surprisingly I had to do very little trimming to make it fit. Would be easy to put the stock radio back in someday if the need arises.
Old 12-29-2011, 03:28 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
went out and grabbed the holder i'm gona mount permanent-ish lol
the dash pad has AC vents gona have this stick out threw that hole somehow
wired to switches,
the lighter plug one flips sideways in the plug ,when turning
i sure like the radio,this makes it hands free and charger too
John
Old 12-29-2011, 05:03 PM   #15
WAAF
1000 words
WAAF is offline   Reply With Quote
Old 12-29-2011, 06:53 PM   #16
Firebirdjones
wired to switches,
Okay I give. What is that stuff??
Old 12-29-2011, 09:10 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
the one on the right is complete
i lost the screw in fuse tip on the left one,going to hardwire it in
they were $30.00 at first, the other day $12.00 Christmas special at Canadian Tire
complete it plugs into the lighter,charges iphone/pod,
plays the music or phone threw the radio,headphone plugs into unit
there is an ajustable frequency on the top edge,to find a clear FM channel
The tip twisted loose in the lighter plug,when turning the truck and i lost the spring/fuse/tip one day,
bought a second one $19.00 .....lost a third one and now we have a fourth
so i plan to hardwire the "broken" one in an AC dash hole sticking out where i can see/use it
applying power to the loose "wires" it works as normal
I found out you can use it hands free using the ipod power from the radio instead
so power from say the lighter "power"to the transmitter is built in it,and now I don't need the black "extra" pod plug
but the radio runs/shows the song list etc in the display,when using the ipod plug to it
source change from iphone to radio to answer the phone,quick and ez
lol trying to explain it seems to get more confusing
but it works ...http://youtu.be/7lqXLgFScHw
John
Old 12-29-2011, 09:36 PM   #18
Firebirdjones
Yeah that's confusing
I just simply use a small device (about the size of a credit card and nearly as flat) that stores about 600 songs. It just plugs into the USB port to the right of the radio (you can see it in your picture). I use the radio remote control to flip around songs. Very easy to use and sounds great.
When I want more songs I just bring that little device in the house (MP3 player) and plug it into the house computer and burn the songs in.
It's like having a CD player without all the CD's.
Old 12-29-2011, 09:47 PM   #19
grancuda
grancuda's Avatar
I put my stereo under the seat along with a amp & 6" Bazooka tube. *I put (2) 3 1/2" in the factory dash location. *I put the antenna in the rear passenger pillar. *Put a mirror on the heater box and found the right position to work the remote. *Worked good till I sold that truck. *Probably do the same with the new truck.*
grancuda is offline   Reply With Quote
Old 12-29-2011, 10:09 PM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
yup thats just another type like the iphone/pod
bet that works great just not sure how long that would last using it in salt/snow areas
hop in kick the snow off your boots,might kill it
John
Old 12-30-2011, 01:38 PM   #21
Firebirdjones
That's creative for sure.
I'm more of the KISS principle I didn't grow up among the boom stereo stuff, that's past my time so it was never my thing. Couple speakers is all I need. As long as I can hear it I'm happy.
