how do i know what rear end is in my 69 and whats the best rear end to have
I have a 69 custom/10 1/2 ton, was a 350 with a 4 barrel and 350 trans, its now sporting a Pontiac 350 still a 350 trans, gonna build a mild 383 stroker, still not 100% sure what I'll do for the trans but the truck will be used as a daily driver, it will see a few runs at the drag strip and im sure ill do a good bit of hauling with the old girl, ive heard alot about dana 60's and also read some about them on here, what the best/easiest rearend to build or just leave alone for 450-600 HP and about equal torque numbers and do a 4 wheel disc setup?
http://67-72chevytrucks.com/vboard/s...d.php?t=438550 ![]() ![]() 1994 Buick Roadmaster 1994 GMC Sonoma |
Re: how do i know what rear end is in my 69 and whats the best rear end to have
And how do I tell whats under the truck now?
Your differential is probably a 12 bolt unless someone changed it out. Count the bolts holding the cover on the rear end. It should have 12 fasteners holding it on.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
