12-19-2011, 10:18 AM | #1 |
Gas treatment
I now understand why the TEXECO down the street from my house doesn't have very many customers. I have filled up twice with in the last two weeks and I’m now having problem when I get lower then 1/4 of a tank. What is a best gas treatment or additive to remove water from my tank?
12-19-2011, 01:19 PM | #2 |
Re: Gas treatment
dont get fuel with ethanol, otherwise drain the tank or burn it off
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-19-2011, 01:43 PM | #3 |
Re: Gas treatment
right like you can do that - "get gas with out ethanol" -
12-19-2011, 02:16 PM | #4 |
Re: Gas treatment
the gas treatments are about the same chemical. one station here sales gas without corn liquor added... the six don't care.. i think it would run on a pine knot if it would fit in the tank,,
12-19-2011, 03:50 PM | #5 |
Parts and more parts
Re: Gas treatment
There is a product made by Penray, that is called NOX-ICE. It is an additive like the old HEET, but it works a little different. HEET will mix with the water and settle to the bottom of a tank, where the NOX-ICE will mix and make a burnable mixture out of teh water and fuel additive. I used to work at a Highway Department and we used this stuff all of the time in the snowplow trucks.
Frank |
12-20-2011, 11:27 AM | #6 |
Re: Gas treatment
12-20-2011, 12:07 PM | #7 |
Re: Gas treatment
HEET and SEA FOAM
12-20-2011, 02:51 PM | #8 |
Re: Gas treatment
ok thanks guys
12-20-2011, 04:13 PM | #9 |
78 Big10 454
Re: Gas treatment
You might want to try STA-BIL.
http://www.goldeagle.com/brands/stabil/ It's pricey, but I swear by it. When I had a company car, I put less than 2,000 miles on my square over six years time. The gas, obviously, got real old and STA-BIL came to the rescue every time. Even though I'm retired and drive the truck on a regular basis, I still keep a bottle or two on hand. Never know where you'll get some bad gas.
1978 Chevy SWB C-10 2WD 454/400 |
12-20-2011, 04:18 PM | #10 | |
Re: Gas treatment
Frank
Born and proudly residing in a Red State ! |
12-20-2011, 05:37 PM | #11 |
Re: Gas treatment
I have had good sucess with Lucas products and I believe they have one for that problem.
12-20-2011, 08:56 PM | #12 |
Re: Gas treatment
I swear by lucas products.
12-20-2011, 09:09 PM | #13 |
Re: Gas treatment
Can't beat seafoam
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
12-22-2011, 05:51 PM | #14 |
Re: Gas treatment
Seems to me Heet is just high priced Methanol, which can be bought by the gallon. 99% Isopropanol (Isopropyl alcohol) solubilizes the water into the gasoline nicely. It can be had at most drug stores. Been using it for many years.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
12-22-2011, 06:31 PM | #15 |
Re: Gas treatment
i had sensor pproblems with the new gas in my HHRss would use seafoam on a regular basis with very short term results
switched out and tried berrymans for about 1/3 the price , problem solver no check engine light since i used it 6weeks ago// with seafoam only lasted 2weeks at the most usually less
12-22-2011, 07:40 PM | #16 |
Active Member
Re: Gas treatment
I gotta drive over 150 miles and probably pay thru the nose to get it. Ain't worth it for me. So far I've been lucky in this area. Haven't had much problems.... yet.
What gets me is that the government is still subsidizing and insisting on using the ethanol mixture. Everything I've ever read says that it's not saving the environment since you have to truck the ethanol rather than pipeline it and has diminshed the longevity of many products. More landfill junk. To me it's another one of those "feel good" things that someone thought was a good idea at the time. Now it's a nightmare. |
12-22-2011, 08:05 PM | #17 | |
Newbee
Re: Gas treatment
12-22-2011, 08:31 PM | #18 |
I built it
Re: Gas treatment
and cars that use ethanol usually get worse mileage then the same car runing normal gas. to me it seems like a waste of money to make/use...
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
12-23-2011, 05:23 PM | #19 | |
Dino burner
Re: Gas treatment
If you want to completely eliminate water, then you'd want to make modifications to the fuel line so that a fuel filtre/water trap unit is plumbed in. But, I think that's more than what you need to do, but it's an option nonetheless. |
