Old 12-19-2011, 12:38 PM   #1
MisterC
MisterC's Avatar
What to use for Choke Delete
Hey Guys.
I'm ditching my choke cable, as it's no longer needed. I've seen several dash pictures that show plugs in that hole. Since I'm too lazy to look mysel, for plugs that will fit, I was hoping some members could let me know what they've used to plug the hole and provide some pictures to help me in my decision.
Thank you.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 12-19-2011, 12:55 PM   #2
1963c-10
1963c-10's Avatar
Re: What to use for Choke Delete
How about the lighter delete plugs? They can still be found in the junkyards pretty easy and its factory correct
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-19-2011, 03:20 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I would just leave it, and wrap the cable up and ziptie it under the dash somewhere
Old 12-19-2011, 03:30 PM   #4
clemdaddy
clemdaddy's Avatar
i put a cheap headlight switch in mine and wired to the 66 backup lights.
clemdaddy is offline   Reply With Quote
Old 12-19-2011, 03:38 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
If you want something that looks like a correct vintage piece, you could just use a chrome spring finger hole plug. Our local tractor supply store has a variety of sizes to pick from. I believe the choke hole is probably around 3/8” – 1/2". The lighter hole is much bigger. You could also paint the plug if you don’t want it to be conspicuous.
Here’s a link to the style sold by Lowe’s. I’m not sure what selection they offer as far as sizing goes.
http://www.lowes.com/pd_139389-37672...ductId=3013213
There are even smaller sizes designed to fit into an allen bolt socket head.
http://www.fastenal.com/web/products...ex?sku=0185764
Old 12-19-2011, 04:39 PM   #6
1963c-10
1963c-10's Avatar
"I believe the choke hole is probably around 3/8” – 1/2". The lighter hole is much bigger. You could also paint the plug if you don’t want it to be conspicuous."
I agree with MarkeB, You would definitely have to drill it out larger, but the plug would be period correct....guess it depends on what your plan for the truck is. Could also use the cable pull for something else....get crafty with it. Ive toyed with using the throttle knob and a longer cable and trying to make a locking hood latch....still in the blueprint stage
Old 12-19-2011, 05:08 PM   #7
jonzcustomshop
1961 crewcab
combined with a 79-87 inside hood latch, I like this idea!
