Old 12-19-2011, 04:47 PM   #1
Bert W
Bert W's Avatar
Engine Mount Question, to change or not to change
Where I come from they are called motor mounts. Anyway, my engine is almost finished at the machine shop. I have read through Roj2323 mount swap. Here for ref:
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
The block I am using is an 86 model. Should I do this conversion or just use the standard setup that was on my 307, new of course? The engine is not much more than stock, small cam, headers, 4bbl, etc. Thanks for any enlightenment you may have on the subject.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 12-19-2011, 05:06 PM   #2
AusTx68
AusTx68's Avatar
Re: Engine Mount Question, to change or not to change
Why would you considering using the 73-87 mounts? Is there something you like about them? I say stick with what you have or go to a tubular aftermarket set. They will bolt right in.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 12-19-2011, 07:31 PM   #3
cdowns
cdowns's Avatar
the originals lasted 40 years
Old 12-19-2011, 08:09 PM   #4
WAAF
isn't the 73 up interlocking type..
a failed motor mount can hang the throttle open..
if a lead foot, thats reason enough
WAAF is offline   Reply With Quote
Old 12-21-2011, 11:35 AM   #5
Bert W
Bert W's Avatar
Thanks for the input fellas!
1983 K5 Blazer
Old 12-21-2011, 12:18 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
Bert,
I used the 73 up style with clamshells for my build. The main reason, I have had a few of the oem style fail in my big block truck. You can add chains or cables to keep if from over traveling in the event of an over torque situation. I prefer these style mounts. Just my 2 cents. I had to drill a few hole to use them. But I am also using an LS engine in my build.
mcbassin is offline   Reply With Quote
Old 12-21-2011, 12:40 PM   #7
hjewell2
hjewell2's Avatar
Right there is reason enough to change them. 40YRS old biscuit style mounts.
hjewell2 is offline   Reply With Quote
Old 12-21-2011, 01:40 PM   #8
MARKDTN
I would swap. There is definitely a reason that GM went to interlocking mounts. On my '64 Impala I broke a mount which put the fan into the shroud which bent both. If I hadn't had a steel shroud, it would have gone through the hood or at least dented it. If I hadn't been at a low speed it probably would have gotten the radiator too.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-21-2011, 02:19 PM   #9
mcbassin
Still Learning
mcbassin's Avatar
I forgot about my buddy's truck that shelled his radiator when his broke. He had the old school flex fan that chewed the crap out of the fins on the radiator when he launched and the mount gave. wasn't pretty.
40 year technology isn't always the best.
Old 12-22-2011, 12:12 PM   #10
haminator
haminator's Avatar
The originals really are'nt that good but I myself can't bring myself to switch. I still insist on running the drivers side alt. too. I'm kinda weird that way. I wouln't even go to HEI until about 1995.
haminator is offline   Reply With Quote
Old 12-22-2011, 01:04 PM   #11
MARKDTN
I'm not sure I would go out of my way to change them on a driving vehicle, but if I already had the engine out it would be a good time.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 12-22-2011, 03:37 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you wanna use OEM type, then you might want to scrounge up one of the restraints that GM installed as a result of the recall notice when the motor mounts started coming apart. Here's a pic of the loop that mounts to the chassis. Then, you need to fabricate a duplicate of the cable that went through the loop and around the exhaust manifold. If you run OEM manifolds and have OEM motor mounts, the cable and loop will lend an air or authenticity that all is as GM intended for it to be.
Member Nr. 2770
Old 12-22-2011, 07:49 PM   #13
haminator
haminator's Avatar
I have only seen one truck with those cables still on it. What years were recalled? Wonder if they'de still honor that recall? lol.
Old 12-23-2011, 10:59 AM   #14
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Get the poly mounts from Summit. They have an internal locking feature if they do break.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 12-23-2011, 11:58 AM   #15
haminator
haminator's Avatar
Great idea.
