04-22-2003, 08:31 PM | #1 |
not a very good day working on the truck!
so i put a brand new water pump on my new 383 i get. and have to pop off the rear cover to compress the pump so the pulley lines up nice with the crank pulley. put the cover back on. now about 2 months later i get the truck running and the cover leaks. i think nothing of it and just get all new gaskets to redo this job and be over with it! that doesnt happen and i get it running after taking a long time and doing a nice job and it leaks again! even worse! i guess this is just a part of working on old stuff. its a blast to work on though.
matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
04-22-2003, 09:08 PM | #2 |
Chances are you busted the shaft seal pressing on it and are going to need another new pump. When I did my friends 350 last month he put a fluid damper on it we had to make up a shim for the pulley on the water pump, to move it out .060 to get the pulleys to line up.
04-22-2003, 09:54 PM | #3 |
hay i just spend 20,000 on my new engine and trans. dropped a
valve...in only 4 days...(under warrenty) but just pulled it out again ....only wish it was a water pump.....hope this makes you feel a little better |
04-22-2003, 10:14 PM | #4 |
NOOO more bad news! haha dont tell me this!, i bet we did break that seal to now that i think of it. would that make the antifreeze like wanna come out really fast and you can actualyl hear it sizzling away ? thanks
04-22-2003, 10:30 PM | #5 |
actually breaking that seal, wouldnt it come out the front side? mine comes out the backing plate there. i think im going to try one more time with all new gaskets and a lot of that rv stuff, and let it set up over night. if that doenst work then ill have to fork out some more $$$$ for a new pump. thanks guys
matt
