Old 12-19-2011, 08:22 PM   #1
Knothead
Knothead's Avatar
'2000 Transfer case making noise?
Works in high range,but nothing in low? How difficult are they to rebuild? Or would I be better off finding one in a junkyard?
Knothead is offline   Reply With Quote
Old 12-20-2011, 10:50 PM   #2
gmclowsierra
Re: '2000 Transfer case making noise?
what do u mean nothing in low? do u have the trans in neutral and stopped before shifting into 4 low?
gmclowsierra is offline   Reply With Quote
Old 12-21-2011, 03:51 PM   #3
Knothead
Knothead's Avatar
After selecting 4 low the truck does not pull at all. That,s when the grinding noise starts?
Old 12-21-2011, 07:53 PM   #4
gmclowsierra
does the light for four low stop blinking like its engaged? it might be an encoder not shifting fully or its possible but not likely the gears stripped out
Old 12-21-2011, 08:28 PM   #5
Knothead
Knothead's Avatar
I think you may be right. I was messing aroud with the push buttons today. I lost 4 high & 4 low. I could hear the transmission turning but had nothing out the transfer case. Works fine in 2 wheel?
Old 12-22-2011, 10:17 PM   #6
gmclowsierra
is the service four wheel drive light on? it might be an internal problem. should still move when shifted into four wheel high or low at least the rear axle should be locked in.
