Clutch question
So, an hour after my neighbor borrowed my 3/4 ton, he calls and asks if it has been having "Problems". Roasted the clutch. This will be the fourth time I have changed it out in 12 years. My local parts guys offer a new one, $120 bucks, or one that is more heavy duty, for $190. Is there really a difference, and if so, is it worth it? She hauls heavy loads for me all the time, but not for the neighbor anymore. Thanks
On a budget like Fred Sanford
Re: Clutch question
HD kit is likely a pressure plate w/heavier base pressure and/or different friction material on the disc. Might be worth the upgrade if you're burning through them faster than you should be with the work the truck does.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Re: Clutch question
That sounded to be more frequent than it should be. Thanks
Re: Clutch question
how many miles per clutch?
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
Re: Clutch question
Not that many at all. Less than 10,000, but all of them are hard. Heavy loads pulling heavy trailers.
![]() Join Date: Sep 2010
Re: Clutch question
I would go HD for sure with your work loads. Hayes makes some pretty strong ones available at JEGS
Re: Clutch question
I think the one you have is the 11 inch right? You can do a heavier clamp load with an upgraded pressure plate and organic clutch, replace the bushing for a pilot bearing and a throw out bearing. I don't know how to do mine, I want a 12" flywheel with a heavy pressure plate and an organic one for heavy hauling. The only issue I have is adjusting the starter.
Re: Clutch question
I would make sure the neighbor knows how to drive a stick... my 77 still has the original clutch in it and it has 214000 miles on it me personally I would go with the heavy duty clutch so here is a question for you do you have your flywheel surfaced when you install a new clutch. if not you might want to have that done to
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() |
Re: Clutch question
i would go for the hd just to help it out some, but who uses the clutch once your moving anyways lol
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s ![]() |
Re: Clutch question
Resurface the flywheel and use a 3200 lb Ram plate.
Re: Clutch question
The HD will be a brass woven organic disc and it will have the same pressure plate load as OEM. The Brass/Organic mix is great for towing when someone that knows how to drive a stick and towing. Like others said, resurface the flywheel, replace the pilot bushing, and look into your clutch release setup.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
Re: Clutch question
Great insights. I resurfaced the fly 2 clutches ago, but not on the last one. I will do that, and upgrade to the hd.
