Old 12-20-2011, 06:28 PM   #1
northeimcustom
northeimcustom's Avatar
power steering pump bracket puzzle
am i missing a piece? how does this go together, i forgot! pics help!
northeimcustom is offline   Reply With Quote
Old 12-21-2011, 02:02 AM   #2
northeimcustom
Re: power steering pump bracket puzzle
Nobody's seen this set up before?!
Old 12-21-2011, 02:08 AM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
let me look at my friends but the one the left i think goes to the pump and the other to the header
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-21-2011, 03:15 AM   #4
rwhit57
rwhit57's Avatar
It ties in with the A/C bkt. Without the A/C I think you'll either need a non A/C P/S bkt or do some fabricating. I think, maybe someone else can help or I can look at mine when I get home.
rwhit57 is offline   Reply With Quote
Old 12-21-2011, 05:17 AM   #5
72lb4x4
The 2 holes on the left side of the pump in front of the header tube slide in front of and in back of a hole in the water pump. That's the hole on the left side of the pic in the water pump.
The bracket on the left of pic 3 looks like you can turn it so the square nut can be bolted to the elongated adjustment hole in the other bracket on the PS pump. The hole below the square nut will have the front header bolt go through it. You'll probably need a 1" spacer tube and a 2" or so bolt since you now have headers.
72lb4x4 is offline   Reply With Quote
Old 12-21-2011, 11:51 AM   #6
northeimcustom
Thanks a bunch guys! A picture would help a lot
Old 12-21-2011, 04:47 PM   #7
INSIDIOUS '86
picture 1
i will take a pic of my friends powersteering
rwhit57 said that if you have ac and took it off you need diff brackets so what you have wont work
Old 12-21-2011, 07:04 PM   #8
northeimcustom
no ac before or after i took it apart
Old 12-21-2011, 07:28 PM   #9
Desert1957
Desert1957's Avatar
Desert1957 is offline   Reply With Quote
Old 12-21-2011, 07:40 PM   #10
northeimcustom
hmmm, ya , thankyou but no ac.....
Old 12-21-2011, 08:42 PM   #11
72lb4x4
Are you able to figure out where the pump should be located by looking at the red line in the pic?
Old 12-22-2011, 01:18 AM   #12
INSIDIOUS '86
this is what I did to mount mine...
I got some muscle and steer it manually like a man
Old 12-22-2011, 12:57 PM   #13
patrickth
Almost looks like you are missing piece. Here are some pics of mine.
Its on an 81 I just got.
patrickth is offline   Reply With Quote
Old 12-22-2011, 01:21 PM   #14
Dan1969
Pffft, my engine looks much dirtier than that...
And my pump looks exaclty the same as your bracket. Seems like OP is missing something in there.
Dan1969 is offline   Reply With Quote
Old 12-23-2011, 12:33 PM   #15
northeimcustom
ya i think i am missing something, crap.
anyone know of a good easy cheap aftermarket bracket set up i can buy??
Old 12-23-2011, 01:04 PM   #16
Dan1969
upon closer inspection, you seem to have everything. the red line a few posts up goes into the water pump and that's the pivot point for tensioning. The other two pieces are like a puzzle to secure on the header/body of the pump with the sliding capability for tensioning. Just look closely at the pictue and you'll figure it out.
Old 12-24-2011, 12:45 AM   #17
patrickth
I couldn't swear to it with pics posted, but put
200672716750
into ebay search box. If you don't have it, you most probably need it.
I agree you may already have it but need to mount the small one at an angle so that it fits header. I think that is a double bolt and nut, or it is on mine anyway.
Old 01-14-2012, 10:09 PM   #18
SRVBLUES64
I bought this bracket from a member on this forum for my 66 c10 with a 350 I cant seem to make it fit. I think its the wrong bracket
SRVBLUES64 is offline   Reply With Quote
Old 01-14-2012, 10:35 PM   #19
northeimcustom
just installed this today
http://www.ebay.com/itm/300637838092...84.m1497.l2649
easiest fix nice quick simple
Old 01-14-2012, 11:17 PM   #20
patrickth
Take the pump out of the equation for he moment.
The bracket mounts on water pump and head. Once that lines up, then introduce the power steering pump where the pulley is aligned facing forward and lined up with belt.
Once that is done, you will see that you need yet one more small piece that bolts to exhaust. Look at my pic posted, you will see it there.
Old 02-01-2012, 08:30 PM   #21
SRVBLUES64
Im also having big issues can some buddy help me out? check my pics out Thanks Jeff
Old 02-01-2012, 09:22 PM   #22
patrickth
Look at my post above. Safely remove the puppy from harms way. Take only the bracket and line it up to the head as posted previously. Once that is done, with the cap on and pump facing up, manuever it until holes line up. It should not be a mystery at that point.
You are going to have to remove the top bolt on water pump. It shares the location with power steering mount.
Old 02-01-2012, 09:32 PM   #23
SRVBLUES64
me and a the mechanic whose working on it says this is the wrong bracket
Old 02-01-2012, 11:43 PM   #24
patrickth
I found a good pick of that bracket in use on a jeep.
http://www.earlycj5.com/forums/showt...ing-conversion
Old 02-02-2012, 07:21 AM   #25
SRVBLUES64
Thanks for all the info but the holes dont even line up on the pump
