Old 12-20-2011, 08:17 PM   #1
Dano51
Exclamation Volare motor mount
Does,Anyone have plans for motor mounts ,for a volare front end in a 55-59 chevy pickup. Picture would be nice too. Dan
Dano51 is offline   Reply With Quote
Old 12-21-2011, 02:15 AM   #2
parkwood
parkwood's Avatar
Re: Volare motor mount
could we see some pictures of the Volare front end? might help you come up with something..
parkwood is offline   Reply With Quote
Old 12-21-2011, 03:05 PM   #3
38 Hump
I have a '58 with the Volare K-member installed. The engine mounts happen to be very visible right now since I have the frame stripped and mounted to a rotisserie. The only problem is I don't know how to transfer a picture from my camera (Kodak) to the Forum.
As an aside, I have had the Volare in the frame since 1988. I have the answers to almost (?) any question you may have regarding this swap (not bragging... just have ran into almost every problem possible!). Very rare to see a Volare in a Chevy. I am currently building with a big block, Muncie 4-speed and 9".
Larry
38 Hump is offline   Reply With Quote
Old 12-21-2011, 03:27 PM   #4
Indian113
Indian113's Avatar
38 Hump,did you have trouble with the steering box on you IFS ?
Indian113 is offline   Reply With Quote
Old 12-21-2011, 10:35 PM   #5
Dano51
Do you think you can find someone who can take some picture of the motor mounts , And put them on here. Thanks Dan
Old 12-22-2011, 01:49 AM   #6
OrrieG
OrrieG's Avatar
If you can get it on your computer used the "manage attachments", "browse" under upload file from your computer. It will usually resize it, if it is to large you will need to open it on your computer in Paint (right click>"open with"), click "image" then resize same percentage and save with a new name. Close Paint and use manage attachments to upload.
OrrieG is offline   Reply With Quote
Old 12-22-2011, 12:22 PM   #7
mknittle
mknittle's Avatar
Larry
oops
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-22-2011, 12:28 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Larry
If you can send the pictures to my regular email, I will post them for you here
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-22-2011, 12:32 PM   #9
mknittle
mknittle's Avatar
MY wife the computer expert. By tomorrow this thing should be fixed beyond repair!
Mark
My GMC build.
Old 12-22-2011, 02:01 PM   #10
Kabwe
Certified Car Nut
Kabwe's Avatar
It does not matter what vehicle the volare clip is installed in. I've done them on Chevy's and and Ford's. The problem is the big bulk steering box. You have to offset the engine to the passenger side and fab your motor mount. Header choice may also be an issue.
Kabwe is offline   Reply With Quote
Old 12-22-2011, 07:20 PM   #11
Chevette
Chevette's Avatar
I just sold my entire chassis/with Volare clip. I used 2" band iron over steering box/to motor and down to top of cross member. Other side is easier. Sorry about the pics. They're the only ones I had.
Chevette is offline   Reply With Quote
Old 12-22-2011, 07:51 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Thumbs up Re: Volare motor mount
Here are pics from 38Hump:
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-23-2011, 01:14 PM   #13
mknittle
mknittle's Avatar
seems like the center of gravity ends up being kind of highot clear the steering box. otherwise it looks a lot like a mII. doesn't that have torsion bars?
Mark
My GMC build.
Old 12-24-2011, 11:36 PM   #14
Dano51
Old 12-26-2011, 05:02 PM   #15
Dano51
Old 12-26-2011, 05:04 PM   #16
Dano51
Here is what i came up with, after a little redesign.
Old 12-27-2011, 11:11 PM   #17
oletrux
oletrux's Avatar
As I recall, they have torsion bars that 'criss-cross' on the forward side. They are adjustable too........
oletrux is offline   Reply With Quote
Old 12-28-2011, 02:15 AM   #18
Chevette
Chevette's Avatar
True, they are adjustable, but if you adjust them down as a means of lowering the front of your truck, you will find the ride is very soft and sloppy. To get a good low front stance you can purchase a 2" drop spindle from Fatman Eng. for about $450. The Volare is a decent suspension, but it doesn't compare to a good MII type front end. I never required any replacement parts for mine, but I would assume they're getting harder to find.
Old 12-28-2011, 01:04 PM   #19
oletrux
oletrux's Avatar
When I bought my truck it had a Volare IFS scabbed in....I replaced it with a Mustang II. No regrets.
