Old 12-21-2011, 12:37 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
6 lug front disc brakes
so.. with dropped spindles you can't keep the drum brakes...
I do want to stay 6 lug to keep my wheels.
saw a "kit" on ebay for $700 shipped that is the complete setup: spindles bearings rotors and calipers...
wondering if it would be cheaper to source some of it from junk yards/ auto parts store....
I have a few camaro/transams that I could pirate some calipers off of.
I had heard that you can just use 90's nissan/toyota 2wd 6 lug rotors from the auto parts store...
anyone piece one of these setups together?
got part #'s or suggestions?
should I just save up and buy new?
Old 12-21-2011, 12:50 AM   #2
Captainfab
60-66 Nut
Re: 6 lug front disc brakes
Why not use the '88-'98 light duty C2500 parts. The conversion is described in the 'Dics Brake Upgrade Reference' thread. The parts to do it should be fairly easy to come by. This is what I will be doing to my Suburban........someday.
Old 12-21-2011, 12:52 AM   #3
blackedoutharley
Isn't just easier to get some spindles from a '73 up C-10, with all the assorted hard parts and buy the 6 lug rotors that are offered in the kits from such places as CPP or POL?
blackedoutharley is offline   Reply With Quote
Old 12-21-2011, 01:07 AM   #4
63chevyll
gets board easy.......
63chevyll's Avatar
That makes more sense
63chevyll is offline   Reply With Quote
Old 12-21-2011, 03:02 AM   #5
jonzcustomshop
1961 crewcab
out of curiosity I wonder if the 6 lug rotors that are offered by cpp and others are the nissan/toyota ones?
Old 12-21-2011, 05:23 AM   #6
blackedoutharley
No, they are stock replacement rotors that are drilled 6 lug rather than 5x5" (except the drilled/slotted ones of course).
From what I understand they buy the blanks before they are drilled 5 lug and have them drilled six lug instead. Uses stock replacement bearings, seals etc. Don't know if the wheel studs are 7/16" or 1/2' though.
Old 12-21-2011, 07:03 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
They are 7/16" lug studs.
Companies like Early Classic Enterprises and Performance Online sell these.
http://www.performanceonline.com/FRO...10-TRUCK-8600/
It's the easiest way to get 6-lug disc brakes.
Add them to any 71-87 HD 5lug front suspension that originally came with 1-1/4" wide rotors.
You can buy these rotors in "drilled and slotted" or standard plain rotors.
Just remember,... your old Pre-'71 steel wheels will NOT clear the disc brake calipers.
If you want steelies,... you have to use 71-87 6-lug 4x4 steelies to clear the calipers.
Keith
Convert to disc brakes.
Old 12-21-2011, 07:06 AM   #8
lolife99
lolife99's Avatar
I agree!
Keith
Old 12-21-2011, 07:24 AM   #9
blackedoutharley
Its worth $90 each to not spend my time racking my brain and cobbling something together from assorted vehicles.
Simplicity!
Old 12-21-2011, 07:45 AM   #10
jonzcustomshop
1961 crewcab
yes that sounds simple.. now you are saying 71-87 "hd" suspension.. are there 2 different suspensions available with the 5 lug? and all I will need to do is measure the width of the rotor?
then I can just buy the new rotors?
use the 73-87 control arms , and buy a set of dropped spindles for a 73-87, and then that should all bolt to my 65 X member?
Old 12-21-2011, 08:02 AM   #11
lolife99
lolife99's Avatar
Yes.
Gm built a HD version (1-1/4" rotors) and a Light Duty version (1" rotors).
I would skip the 73-87 stuff or 71-72 stuff unless you have a donor truck,... so you can rob everything, including all the steering components.
Just buy 63-70 conversion spindles and BOLT them on.
Change nothing else.
No a-arm change.
No ball joint change.
No tie rod change.
These conversion spindles ONLY come in the HD 1-1/4" rotor version that you need for the 6-lug rotors.
You can buy these spindles every day for $229.00 at www.performanceonline.com.
Keith
Old 12-21-2011, 08:04 AM   #12
lolife99
lolife99's Avatar
I have this 6-lug disc brake set-up on my '69 swb.
Keith
Old 12-21-2011, 08:07 AM   #13
lolife99
lolife99's Avatar
Another thing about "HD vs Light Duty",... everything has to match.
Spindle, rotor, caliper and bearings.
They are all specific to the "width" of rotor that you are using.
The 63-70 conversion spindles make it easy.
(plus they even make a 60-62 spindle for the torsion bar trucks!)
Keith
Old 12-21-2011, 08:38 AM   #14
jonzcustomshop
1961 crewcab
that thread helps!
Yes.
No a-arm change.
No tie rod change.
this idea seems best! (for me now) I have been on the fence about a steering upgrade(power), but unless I stumble on a cheap donor truck this seems my best bet for now.
I will have some time to think about the options while I am saving up the $$
thanks.
Old 12-21-2011, 09:49 PM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hmmm....
I'm debating which way to go as well on my '63.
Thought about the '88-'98 method, using 3/4 ton lowers to except the correct ball joints. I'm assuming these calipers off better stopping power (??)
Then again, also thought about the '73-'87 a-arms for their rubber bushings...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-21-2011, 10:18 PM   #16
waspp
waspp's Avatar
So dropped spindles and 6 lug discs will not work with my stock 63 rims? Are there aftermarket steel wheels that will work with the disc brake set up allowing you use the stock hubcaps?
waspp is offline   Reply With Quote
Old 12-21-2011, 10:28 PM   #17
cb1965
cb1965's Avatar
great info guys.
im interested in keeping 6 lugs also.
so... if i get the complete front suspension from a 73-87 with 1-1/4" rotors, all i have to do is swap the rotors with the 6 lug? everything else stays the same?
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 12-21-2011, 10:48 PM   #18
lolife99
lolife99's Avatar
No.
The old wheels don't have room to clear the disc brake calipers.
Aftermarket wheels should be fine.
Originally Posted by cb1965 View Post
great info guys.
Yes.
But remember to get the steering stuff.
Centerlink and tie rods.
Keith
Old 12-21-2011, 11:00 PM   #19
cb1965
cb1965's Avatar
Yes.
oh hell yeah! now to save some cash and start hunting! thanks
'66 chevy lwb c10
'65 chevy lwb c20
Old 12-22-2011, 09:41 AM   #20
jonzcustomshop
1961 crewcab
I had some 6 lug steelies off an 75-7 suburban,on my 65, the sub was a 4X4
the wheels didn't look correct without the hubcap, but with the hubcap on you could hardly tell... The "windows" are a tiny bit different
Old 12-22-2011, 10:58 AM   #21
waspp
waspp's Avatar
What is it that interferes with the caliper? Is it the face of the rim that bolts on to the disc or the rim itself? I have looked into having wider steel rims made up using my original centers but maybe that won't work either.
Old 12-22-2011, 11:07 AM   #22
67swb72klb
67swb72klb's Avatar
in my exp it is the rim to caliper clearance problem
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-22-2011, 11:30 AM   #23
lolife99
lolife99's Avatar
Usually it's the rim itself.
There are tons of 71-87 4x4 steel wheels out there.
Most throw them away.
Look on blazers and burbs also.
If not,... Wheel Vintiques makes a Series 62 steel wheel in many sizes that will work just fine for the 5-lug steelies.
I just don't know if they make a 6-lug wheel or not.
Keith
Old 12-22-2011, 12:08 PM   #24
72BlckButy
Tot Roddin'
72BlckButy's Avatar
As Keith said, the kits take the guess work and prevent any return trips to the parts store. Ordered mine from ECE and only had to add bearing grease and brake fluid to the mix; everything was included.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-22-2011, 02:25 PM   #25
69burban
Garage Built Rides
69burban's Avatar
I recently purchased the McGaughy's 6 lug disc kit for my 65 from a local vender here in NM. It was a little over 700.00 with shipping and it came with the big rotors and calipers. Everything looked super heavy duty, nice parts. I'm starting to wonder about my 15" wheels clearing the caliper now too....
Albuquerque, New Mexico
65 long bed,
shaved drip rails, tail lights, tailgate, and molding. 350/700r4, dropped springs
69burban is offline   Reply With Quote
