Old 12-21-2011, 09:00 AM   #1
dthela
dthela's Avatar
62 burb fuel lines
been awhile since i installed the tank, not getting gas out of it. my sending unit has 2 pipes coming out of it. One should be the pickup tube, the other the vent. I suck on the fuel line at the filter, but no gas. maybe i'm not sucking it up high enough? trucks starts and runs on starting fluid but no gas pumping through the line. All fittings clamps tight, no kinks. gasket in filter bowl. WTH? Build and maintenance manual only shows one tube. So close yet so far! And pleeeeeze don't ask me if there's gas in the tank lolol.
dthela is offline   Reply With Quote
Old 12-21-2011, 02:28 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: 62 burb fuel lines
I would pop the line off of the tank and also disconnect it at the pump and blow compressed air through it, just to be sure there is no blockage.
Old 12-21-2011, 06:51 PM   #3
dthela
dthela's Avatar
all brand new. gas cap is open a bit too.
Old 12-21-2011, 07:16 PM   #4
TopFuel1966
TopFuel1966's Avatar
Eliminate the internal pickup as the problem. Disconnect the fuel line at the tank. Block off the vent tube and pressurize the tank with about 5-10 lbs. compressed air. No gas coming out means blockage in the pickup inside the tank.
TopFuel1966 is offline   Reply With Quote
Old 12-21-2011, 08:14 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
I am actually interested to know why your tank has two lines at the sending unit. My '60 Burb only has one for the pick-up and the vent is attached to the filler neck. The only thing I can think of is that the second line coming from your sending unit is not right. Either the lines are connected wrong or somehow that vent is not allowing you to gain suction. Sorry I can't be more help man.
Check out my build thread for my 'burb in my signature and I think on page two or so are the pics of my tank.
