Old 12-21-2011, 10:21 AM   #1
simobones454
simobones454's Avatar
C notch air bags
hi all , maybe a stupid question, but can you mount your air bags between the diff and bottom of the c notch on 1990c1500. Just setting mine up, running 8inch notches and hopeing this will work as i want to run big rubber and the bags between the notchs wont get in the way of shocks and paralle 4 link brackets. any photos would help thanks
simobones454 is offline   Reply With Quote
Old 12-21-2011, 11:50 AM   #2
SCOTI
SCOTI's Avatar
Re: C notch air bags
You can move the bags to the inside of the frame rails. Use mounts that hang off the rear axle tubes & build an upper bag mount x-member that's tied to the frame rails.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-21-2011, 04:32 PM   #3
simobones454
Thanks scoti, still not really understanding how it all works. Any chance of sending drawing or diagrams on where and how it all sits thanks.
Old 12-21-2011, 04:41 PM   #4
SCOTI
SCOTI's Avatar
I'll put up some pics once I get to my home computer tonight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2011, 04:42 PM   #5
simobones454
Thanks mate,
Old 12-21-2011, 04:50 PM   #6
SCOTI
SCOTI's Avatar
Here's one I have on my laptop. Notice the tapered/rolling sleeve style bags sit directly on top of the axle tubes & the top crossmember doubles also locates the upper bag mounts. Your 4-bar set-up would be a slightly different suspension type but basically the same set-up packaging wise....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2011, 05:09 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
Man scoti...Keep this thread G rated...that pic is truck porn!!!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-21-2011, 05:13 PM   #8
simobones454
so where abouts do the shocks go , still can't see why can't put bags between the axles and the underside of the c notch ,or won't the bag have enough room to fully deflate when in slam position.
Old 12-21-2011, 05:47 PM   #9
SCOTI
SCOTI's Avatar
You can put the bags between the c-notch & rear axle tubes but the height of the bags will defeat the purpose of the step notch.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2011, 07:30 PM   #10
simobones454
thanks again for ya help scoti, is this your mates car or someone you know. love to know what size tyres+ rims on it.
Old 12-21-2011, 09:05 PM   #11
SCOTI
SCOTI's Avatar
No, nobody I personally know. Looking @ the tire tread though, I'm gonna guess 24x15's w/Pirelli 405-25-24's.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
