Old 12-21-2011, 11:40 PM   #1
1972RedNeck
1972RedNeck's Avatar
Fuel Filler Neck
I am about to start my next "fix" on my '72 K2500. I am going to put a 31 gallon suburban tank between the frame rails in the back.
I would like to use a suburban/blazer-type filler neck. I want it to be in about the same position as the suburban in relation to the body lines. Has anyone done this?
Also, where can I get a suburban filler neck?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-22-2011, 12:24 AM   #2
TrkEnvy
Re: Fuel Filler Neck
I got mine in the local pic a part.. Out of an 81 suburban. Took me 10 minutes to pull it myself.
TrkEnvy is offline   Reply With Quote
Old 12-22-2011, 12:34 AM   #3
vectorit
What?
vectorit's Avatar
No one reproduces the Suburban 67-72 fuel fill pipe.
Salvage part only, and average cost I see usually is between 30 and 50 bones online. Though you could probably score one cheaper at a yard IF you found one.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-22-2011, 12:44 AM   #4
1972RedNeck
Isn't the 81 neck in a recess covered by a door?
1966 F250 4X4 416
1972 K20 350 4 OTF
