12-22-2011, 11:14 AM | #1 |
Difference between firestone f9000 and f9100??
I would like to know the difference between the firestone f9000 and f9100s. I recently got the 9000s for my c-10 and they look really small. Thanks for any help.
12-22-2011, 11:18 AM | #2 | |
Re: Difference between firestone f9000 and f9100??
The F9000 will do the job just right on your C10. They have a 1500lb load capacity per bag and are designed to be run at a 1 to 1 ratio... that means mounted off the axle and not levered. We design all our rear kits with these bags as they yield the best ride quality, have a more consistent spring rate, and are easy to package into the system.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
12-23-2011, 12:39 AM | #3 |
FWIW, I recall reading these were spec'd for GM pass car coil applications that needed a little more capacity. I believe the upper air fitting is also on the side of the billet end-plate for easier access vs the traditional top of the composite end-plate.
12-23-2011, 01:34 PM | #4 |
The 9100 is a bag that is made by ridetech for GM A body dirrect fit applications... The 9000 is a great bag.
08-26-2013, 09:12 AM | #5 |
67cheby
Do you think the weight of my Square body blazer would benefit from going up to the f9100 ? I have the f9000 now and with the body on I sure cant get much lift .
08-31-2013, 11:36 AM | #6 |
67-72 parts collector,…
The billet topped 9100 bag gets more total lift,... but ride height is almost the same because the 9100 bag has a taller minimum height.
5"-5.25"of lift at suggested ride height. http://www.ridetech.com/store/components/air-springs/
