Old 12-22-2011, 12:20 PM   #1
C-10 simplex
1 ton dually crew cabs with the straight 6:
If you have a dually crew cab with the straight 6, please list the following:
1) The GVWR of the truck----should be on the door sill.
2) The GCWR (if known) and towing capacity of the truck.
3) What rear gear ratio you got.
4) What is, to the best of your ability, the mpg when unloaded and the mpg when trailering and approximate weight of the trailer. Also is the trailer open or box?
Essentially what i'm trying to do is get acceptable fuel economy when unloaded----because i want to use this for daily driving as well, or at least have the option to. But i also want decent high towing capacity. i would define decent towing capacity as the ability to tow a 5000 lbs trailer at 65 mph and not even know that the trailer is there AND be able to maintain 65 mph when going up most reasonable hills without even breaking a sweat.
Yes, i want to have my cake and eat it too. But i don't just want cake, i want extreme chocolate frosting with sprinkles on top of it AND i want to eat it in a sauna with jets.
The reason why i'm not considering diesel is because i'm not familiar with them----the pump and related paraphenalia especially. But also because i think the initial cost is too high considering i won't be doing THAT much driving.
C-10 simplex is offline   Reply With Quote
Old 12-22-2011, 09:00 PM   #2
78maliburat
Re: 1 ton dually crew cabs with the straight 6:
Wow poor 6 banger .............alot to ask for so little
78maliburat is offline   Reply With Quote
Old 12-22-2011, 09:12 PM   #3
Goldfinger
Goldfinger's Avatar
6 bangers are under estimated greatly. They don't do very well in the fuel department but they seem to pull well and last a long time.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 12-22-2011, 10:42 PM   #4
c10sport
c10sport's Avatar
292s are torque monsters.
I've only seen one 6 cylinder CC dually. A 1973 in a junkyard years ago.
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 12-22-2011, 10:51 PM   #5
AntiGov
AntiGov's Avatar
will a six in a crew dually even make it to 65mph.....without the 5000 lb trailer ????
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 12-22-2011, 10:58 PM   #6
75gmc454
75gmc454's Avatar
I would think they are pretty rare. I called about one for sale a year ago. It was a crew cab dually 4x4. I think it was an 81, but not sure.
75gmc454 is offline   Reply With Quote
Old 12-22-2011, 11:05 PM   #7
Goldfinger
Goldfinger's Avatar
a straight six is a great engine. what they lack in horsepower is made up in torque. you have to know that dump trucks and semi's used gas straight 6's for a long time. they are rare to find in larger Chevrolets though
Old 12-22-2011, 11:24 PM   #8
rustyrodknocker
if it was that easy you would be able to pick from thousands of factory built trucks with those options. I have a soft spot in my heart for a 292. but thats way out of bounds. they will do ok on fuel intill you take them out of their rpm range. then you pay the piper. mine with 4:56's would pull that trailer all day. at 50-55 mph tops. unloaded at 65 it was wound up and getting 11mpg. it could get as high as 19mpg unloaded at 50mph. I want a 1/2 ton with 3:08's just for freeway cruising.
rustyrodknocker is offline   Reply With Quote
Old 12-23-2011, 12:16 AM   #9
C-10 simplex
Update: i want cake with thick chocolate frosting and sprinkles AND i want to eat it while inside a hot tub with jets AND i want to be professionally massaged while watching a good movie or documentary. But the massuse must wear earplugs and the view from the screen must be blocked from her view. The reason is that if this wasn't so then her attention(at least partially) would be taken off me and on to movie; i want all the attention on me.
(if i told you i am currently single and likely to stay that way for a while would this not surprise you........)
The funny thing is i'm thinking of building a crew dually with a v-6---the 4.3. The reason i'm asking about the straight six is because i figured they are close in terms of cubic inches.
Old 12-23-2011, 09:09 AM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
with the weight of the dually you would be work'n the 6 hard all the time , there for kill'n the mileage.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-23-2011, 09:23 AM   #11
TexasDmax
[/QUOTE]The funny thing is i'm thinking of building a crew dually with a v-6---the 4.3. The reason i'm asking about the straight six is because i figured they are close in terms of cubic inches.[/QUOTE]
I hope you are gonna turbo charge that v6 or something, because you are goona kill it with a crew cab dually. You will also hate yourself for driving it. I could not imagine any way a v6 would get better mileage that a 350 or LS motor in a truck that heavy. One more thing the 4.3 v6 ain't no 292 straight six in any form or fashion. The 292 is a torque monster, the v6 has little tiny guts that are better suited for an S10.
You certainly can do what you want and I'm all about being different, but I just don't think this is a wise move. You want mileage think cummins 4bt or something.
TexasDmax is offline   Reply With Quote
Old 12-23-2011, 11:36 AM   #12
Stew_Magoo
This. You might not know a lot about diesels, but with a Cummins, you don't need to know a lot. Get fuel from the tank to the injection pump, get power to a shut-off solenoid. That's it, brother! And 4bt's are cheap. They are all over the place in Frito-Lay trucks, with either some 4 speed, or a good old fashioned GM TH400. These trucks go for $3000-3500, from the few I've looked at. The body is aluminum, so figure 2000 pounds times what ever scrap aluminum is going for is money back in your pocket, and a lot of these trucks have eight lug 19.5 wheels that you may want for hauling or you can sell because there are a bajillion people who would like to have them.
Or step your game up with a 6bt and a allison...
http://milwaukee.craigslist.org/pts/2731488066.html
Stew_Magoo is offline   Reply With Quote
Old 12-23-2011, 12:18 PM   #13
muthstryker
muthstryker's Avatar
Size does matter.
Matt
muthstryker is offline   Reply With Quote
Old 12-23-2011, 09:04 PM   #14
yousesteers
I got a 6 in mine a cummins 6bt and it is getting around 19 to 21 empty
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
