67-72 headlight buckets
the black metal part the headlight fits into..
is it the same as all 7" g.m. buckets.. or do I need to find truck ones.. i'm thinking they are all the same.. the new headlights require holes drilled in the buckets for the halo ring and the blue accent bulb .. and need to pick up a pair.. thanks |
![]() Join Date: Oct 2009
Re: 67-72 headlight buckets
I am not sure how many different kinds there are but I know the 67-68 Chevy and the 69-72 are different. I am not sure about the GMC small headlights. Are you wanting new or used?
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
there is a truck or two in j/y here.. but if they been trashed.. I figured other g.m.
its all about the +6 inches
no idea if any par parts swap...
67/68 same p/n 69/70 same p/n 71/72 same p/n all are intechangable, but none swap without work (drilling/cutting) |
#5 | |
not the trim around the headlight.. the part that it sits in.. that the s/s ring bolts to that holds the headlight.. and has 2 adjustment screws and a spring holding it to the core support.. they are different ,? |
I know there not the same as a gmc of the same years but may be the same or similar for 73/79 trucks. I don't really know for sure.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
And here is somewhat proof.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=162 look at the part numbers. Like I said, you can MAKE them work... I learned about this when I put a 68 nose on my 72 burb and didn't have 68 buckets. I had 72 buckets, and 69 buckets. |
Scrapper 1
i used a set of buckets lights from a 1972 to a 1968 longhorn and they fit well
And were your headlights crooked after that?
Posted via Mobile Device |
#11 | |||
Always on the hunt...
![]() Join Date: Sep 2006
![]() 67/68 Chevy both L. & R. side use same headlight mounting bucket OE GM p/n 924535. 69-72 Chevy L. side headlight mounting bucket OE GM p/n 5961886. 69-72 Chevy R. side headlight mounting bucket OE GM p/n 5961887. |
thanks all...
rather have a spare set to hack on.. and leave the originals intact.. incase I hate the new lights, or they blind people .. |
#13 | ||
A guy with a truck
![]() Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#14 |
